running rich, backfiring
Old Sep 7, 2002 | 11:23 PM
lo-n-slo's Avatar
I finally got my truck to run half way decent, no check engine light, and it drives pretty good. But the problem is this, i can drive the truck into town and drive around for about 25-30 minutes stop and go. Then out of nowhere it will just bog down and pop and sputter out the tailpipe. The only way it can be driven again is if you let it set for a while then it will start and run fine, The timing is set at 4 degrees now.
Now the other problem, The truck will start and idle fine but the exhaust coming from it will literally knock you out i was in tears after a few seconds just standing behind it.
Any help would be great, I can give more info on the mods if needed but it is a tbi 350 so you guys should have an idea
Old Sep 9, 2002 | 05:24 PM
lo-n-slo's Avatar
nobody!!!!
I need help!!!!!
Old Sep 9, 2002 | 07:26 PM
flotsamm's Avatar
You scan for codes?
Old Sep 11, 2002 | 02:28 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
I would put money on it being a clogged up cat.
Old Sep 11, 2002 | 05:47 PM
lo-n-slo's Avatar
i think it was the module i replaced it and it seems to have fixed the problem!!!
Old Sep 12, 2002 | 12:16 PM
SHAGME's Avatar
Car: 1988 IROC-Z
glad I didnt put money on it.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
