Pictures of the carb manifold conversion
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Just thought I'd pass these along if anyone was curious as to how to run anything. Its pretty straight forward, it must be if I figured it out
Picture of throttle bracket that's pissy with the vortec manifold
Another throttle bracket
JPrevot's heater valve delete in action, great to open up engine compartment
Very nice, what about the temp sensor for the computer, seems like it would not be as accurate being on an elbow then on an adapter off the elbow, why did you not just plug it in the manifold, the wires were not long enough? I had to extend my wires off my csc for my computer when i went to the rpm.
Car: 89 Shortbox
Engine: 350 Vortec
I have the same manifold but airgap, and I just peeled the coolant sensors wires form the harness a little bit, and just screwed it in at the back of the manifold. That spot is not good, but if you don't change it at least angle it down to prevent an air lock.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
id move that temp sensor and try to get as much of that crap out between it. It will definatly throw the sensor off some. On mine, the port was on the opposit side of the intake so i had to splice the wires to get enough lenth to get over to the other side .
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
My buddy's o2 sensor went nuts when he just extended it so I was scared that would happen with the temp sensor if I just made the wire longer. So far it hasnt thrown a code, so it'll have to do for a temp solution while I get everything else ironed out.
Id like to just get that hole drilled and tapped next to the tstat housing, mabye when it comes off next I will. Freakin holley gives you the manifold drilled out but Edelbrock cant do it for us.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by dimented24x7
Hey brody, how on earth do you get your tranny to shift with the tv cable disconnected?
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
RE coolant sensor location
hey guys just use a older style water neck like on the LG4 that has the coolant sensor/ port vacuum switch on it .
or will that hurt it sense the ECm needs to follow the rise in temp instead of all of a sudden when the t-stat opens and water flows
just a thought
just a thought
Hey Chuck I noticed something. Your TPS hookup and sensor looks way different than mine. Maybe the 88 TBI was different? Is your TBI "ultimated" or is that an aftermarket TBI? the bore looks huge for some reason.
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Yea those are my shoddily performed Ult. TBI mods. Thats another thing I need to work on, kinda index the bores inward. Theres still about .5 mm of metal sticking up before the primaries.
Either that or Ill save my pennies for a 454 ss tbi
Car: 89 Camaro RS
Engine: 355 TBI
Re: Pictures of the carb manifold conversion
you are only runing a 15.500 what is up with that? i thought you would run faster then that.
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Brody, if I can find anything with 2" bores for less than $175 Ill be happy as hell lol. Man people are getting an arm and a leg for those units!
Yea, the et was bad, but the trap speeds were OK. I dont think 92.81 is the high point of the setup either, because my mph went up from 89 to 91 to 92.81 on my three separate runs and I never got a good run in. There's a mid/low 14 in the car with traction and gears - but Im gonna worry about that next year lol. Gotta concentrate on useless things like Calc 3 haha kill me.
mylittleturtle: uhh ... the best I can say is that I dont know lol. I just went with the timing till it pinged then backed off. I didnt have time to time it before I went back to school. The fuel pressure on stock injectors is damn near the top of the pod, but I think Im running rich. I gotta get a gague. The whole setup is raw and sadly I sort of half assed the end of it just to get it done before I went back to school. Once I get a long break to iron everything out Ill be able to post more solid data.
I really really really want this setup to work because it was fairly cheap (heads, cam, and intake cost about $640 all together) and it would be easily replicated. The tbi registry thing we got goin on is a great idea because it gives people a way to see what setup is producing what and that is what is gonna keep the tbi community together. All the tpi guys have tried and true setups that anyone can bolt on to their cars and see 12s... well I want to be able to say that for the tbi community too.
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
RE fast tbi
hey guys
i have been thinking about doing a cross-ever between a TBI and a TPI. I would like to use a TBI for the throttle blades and sensors and do away with the injectors. then have the intake machined to put 8 injectors in it for multiport injection then all you would need is a speed density TPI ecm to control the injectors. i think the TBI could flow more air than the TPI intake can. it would also make for easier tuning and have the power of a TPI with out the hassle of working on a TPI car. i got the idea after looking at my buddies 99 dodge ram 5.9L
correct me if im wrong but, dont people use TPIs 48mm thorttle blades instead of TBIs 1 11/16" blades???
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Actually SC2's idea has already been done, just look in jegs or summits catalogs under MPFI kits, though they have 4 barrel TB's
With 8 injectors, like the TPI's
With 8 injectors, like the TPI's Supreme Member
Car: '00 Chevrolet Corvette
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
I've been wanting to move my heater valve by cutting the hoses and sticking it towards the back of the engine, but it looks like you pretty much just did away with the thing. Is the heater valve not necessary? What are the details on getting rid of it?
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
