Holley 670cfm TBI unit too big?
Old Oct 8, 2002 | 05:14 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I was pondering today, and thought I might just bypass the Ultimate TBI mod and just jump straight into the Holley unit, but I have a question. Would it be too big to run on a rather stock motor? I imagine that they are smog friendly as well.
But which one would be for our motors? All the ones I see are for trucks (4.3L and 5.7L).
Old Oct 8, 2002 | 05:52 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
670 will require a new manifold that will accept a 2" tbi unit. Either the Pro-Jection or a carb manifold with an adaptor. Im pretty sure tim said the edelbrock tbi manifold can be drilled out to 2" also.
At anyways with a stock engine you'll only really get gains from the manifold, but as your engine grows then the intake will be able to grow with it. It wont hurt anything for sure, but Id put the money twards exhaust or gears/posi first.
Old Oct 8, 2002 | 06:34 PM
Car: 91 RS
Engine: 350 TBI
What exactly has to be drilled out?
Old Oct 8, 2002 | 06:35 PM
NJ SPEEDER's Avatar
wihtr the LT1 cam it woudl prolly be ok. i think it woudl be too much for a stock cam though, or at least a lot mroe than the motor needed.
the gasket it coems with is the adaptor. it necks from 2 inch down to the stock size.
later
tim
Old Oct 8, 2002 | 09:43 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
You need chip tuning with the Holley TBI. I stuck it on my engine after my stock injectors went bad. For the price it was worth it-$80 per injector or $260 for a better flowing TBI.
The Holley pulls great and further into the upper rpm, but it just runs too rich down low. I guess it really isn't to different than bumping up the pressure with the stock TBI's regulator.
All in all, there was a SOTP gain, but a loss in the wallet as gas and spark plugs get expensive. The AFPR is pretty nice. oh yeah, listen to Tim, he right on with everything he said. But if you are set on the Holley, they sell 'em with different size injectors. The 502-5 is for the 305 and comes with 57pph injectors. I believe the 502-4 comes with 50pph injectors, which would have been a better choice for my situation, but I did not know about. The one for the 350s are 65pph injectors, but you would run waaaaayy rich even with a cam.
Old Oct 8, 2002 | 10:09 PM
Car: 91 RS
Engine: 350 TBI
$260??
At Summit the unit is $372......now even with the AFPR, would I still need to get a chip custom burned for me?
Old Oct 8, 2002 | 10:12 PM
Car: 91 RS
Engine: 350 TBI
And what exactly was your "situation"?
Old Oct 8, 2002 | 11:03 PM
JPrevost's Avatar
Car: 91 Red Sled
EFI doesn't really care how big the throttle body is, that's mostly a carb issue. You could get a stock Lo3 to idle fine with a 670 unit so long as you had the correct injectors and some skills, a vac.AFPR would help the fuel issue.
The idea of not having enough TB is an issue I hope to resolve when I get the lockers finished I'll be able to datalog the WOT runs with 15 fps. When there is more than a 5kpa loss in MAP it's going to be an air issue.
Right now I've been steady with the 670 and not ever dropping more than 4kpa.
I do think that it's best to focus on other stuff and not until you're making ~230 hp should you even consider the larger unit.
Old Oct 9, 2002 | 08:13 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
You could also put the 305 GM injector pod on there and solve the rich problem and utilize the higher lb/hr holley injectors once your mods exceed your 305 injectors.
Old Oct 9, 2002 | 09:03 AM
Slade1's Avatar
As I recall the 670 TBI comes in a 5.0 L flavor too.
http://www.jegs.com/cgi-bin/ncommerc...22&prmenbr=361
You should be able to get that unit to flow at about the same rate as the stock one, if not, grab an extra FPR to help it further, but I don't see why you can't get the flow down to a decent idle.
The CFM won't change much unless you remove the bottleneck that is your intake manifold. The bores should match the size of the TB else you're not changing it much.
Old Oct 9, 2002 | 10:39 AM
Engine: LO3;383tpi
$260??
Try Auto Zone. That is where I got mine. It may take a little longer for them to recieve it (mine was about 8 days), then say Summit, but for the price, it's a good trade off. $372 is a rip off.
refering to my post two above yours,
That was my ""situation"" Injectors went bad.
I had thought of that idea as well, and it is a good one. However, my stock injectors are bad, so I would have to purchase new ones which add up to $160. I figure I could use that $160 towards chip burning equipment instead. Thank you for the idea though.
92camaroJoe
Jul 29, 2023 07:57 PM
InfinityShade
Aug 22, 2015 08:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
