Silly Q about L03
Old Oct 16, 2002 | 08:55 PM
Tranny Man's Avatar
Silly Q about L03
I have a 88 305 TBI that runs rough under load I think I found the problem. my scanner shows 8-10" Hg at Idle and 19-22" Hg at part throttle isnt this backwards? These readings are measured at the MAP sensor I really need a vac diagram for this car can anyof you help me? Keith
Old Oct 16, 2002 | 09:07 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I am sorry I dont have a response for you or anything but did I read your signature with a RX7 with a 350????? Nice one!
Old Oct 17, 2002 | 08:40 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Have you hooked up a vacuum gauge to the system to verify MAP readings? You may need to increase base timing a few degrees and/or give it a good tune up.
Old Oct 17, 2002 | 06:05 PM
Tranny Man's Avatar
Br harris I forgot to bring my vacuum gauge home from work will do that tomorrow I found a small vac leak (worn out rubber line) this feeds a signal to the heater box I think. I will have better readings on monday. Tanager yep you read it right the supercharged rotory blew an apex seal for the LAST time check out some pix here http://photos.yahoo.com/bc/rx7260z/l...8+RX-7&.view=t Keith
Old Oct 17, 2002 | 09:28 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you dare cut a car up like that
hehe to each there own
but if you could I woudl like more info on the car
Old Oct 17, 2002 | 10:16 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
when i had a lo3 i got 22" of vaccuum at idle with a carb
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
anesthes
Sep 21, 2015 10:24 AM
Zant69
Car Audio
Sep 22, 2000 01:02 AM
Bandit76
Car Audio
Sep 11, 2000 11:48 PM
