99 dollar slp differential
Old Oct 20, 2002 | 05:00 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
Is the O.E.M. Zexel-Torsen differential from slp a new or used diff?
Old Oct 20, 2002 | 07:49 PM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
I think its used... dont they pull them out of 4th gens
Old Oct 20, 2002 | 08:20 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yes, they're used. They probably have about 10 miles on them at the most. SLP pulled them out of brand new Z28's. Even though the car was never titled, they still have to sell them a take-offs (i.e. used) because the car was driven with them installed.
AJ
Old Oct 20, 2002 | 09:33 PM
chevy8ford's Avatar
Car: 88 Firebird
Don't you have to get new axles to use that diff? I thought that before 93 was different? Or would it work in an 88' without any new axles?
Old Oct 20, 2002 | 11:10 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
yeah they will work in a 88.
and you will like it
Old Oct 21, 2002 | 12:27 AM
chevy8ford's Avatar
Car: 88 Firebird
Wow, what do you have to do to put it in?
Nice pic
Old Oct 21, 2002 | 07:29 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Like to remind you that this is a carrier 3 differential so you will have to get different gears that are carrier 3 gears. So might as well pick up a set of 3:42 or 3:73 GM Motive gears. You will also need a shim kit but the rear end shop will have it for you usually if u don't already. Also I can't remember the name of the stuff but its a lub that is need for limited slip differential installs. You can get it at autozone, anyone remember the name? Its been so long since I installed my gears and SLP differential.
Old Oct 21, 2002 | 07:32 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I thought that 89 was the changeover year for the 28 spline axles and only some of them go 28's.
Old Oct 21, 2002 | 10:38 AM
deadtrend1's Avatar
No 88 and up ..........
Old Oct 21, 2002 | 10:56 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
No he is correct, its 89 and up. But you have to be careful because even some 89's still had the 26 splines for what I have heard.
Old Oct 21, 2002 | 12:42 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Yes the switch was in 89. And some of them have 26 spline. Mine does and it sucks.
Old Oct 21, 2002 | 07:41 PM
chevy8ford's Avatar
Car: 88 Firebird
Oh, ok, so we have established that it will not work in an 88 unless you change the axles. Hmmm...interesting now that 99.00 doesn't seem so worth it
Old Oct 21, 2002 | 09:00 PM
Old Oct 21, 2002 | 09:24 PM
chevy8ford's Avatar
Car: 88 Firebird
Brody, did you have to change your axles? If so how much were they?
Old Oct 21, 2002 | 09:46 PM
i have a 92
Old Oct 22, 2002 | 01:26 AM
Car: 89 Camaro RS
Engine: 355 TBI
I have an 89 and im going to order it friday. is there a way to tell if i got the 28's or 26's in my car
Old Oct 22, 2002 | 07:14 AM
Can't tell the number of splines without pulling the axles.
If you have 26 spline axles, I recommend just getting a 90+ V6 rear from junkyard since they have 3.42 gears and then you can just bolt in the SLP Posi and be done with it.
Old Oct 22, 2002 | 07:53 AM
TBI305Camaro's Avatar
damn you brody you had me excited for a second...I thought maybe I wouldn't have to change my rear but I guess I do. So a 90-92 v6 will already have 3.42 gears...thats good I guess Ill try to find one and get the rear out of it and use the SLP posi...why did they take these carriers out of z28s?? I mean before they were titled whatever.
Old Oct 23, 2002 | 03:17 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
For those of you that have 26 spline axles, you could always buy better axles. I decided to get some Moser 28 spline axles and the Zexel Torsen diff from SLP. I'm quite happy with my setup.
Old Oct 23, 2002 | 03:38 PM
This was done by SLP during the conversion to the SS. You could get an optional heavy duty auburn or eation (don't remember which) clutch type posi instead of the Zexel. No really good reason to change them. That is not the problem with f-bodies. It's the 7.5 gears that will break. The option should have been for a 12-bolt. Then we could ****** them up from the wrecked SS's for almost reasonable costs.
Old Oct 23, 2002 | 04:14 PM
vjo90RS8's Avatar
Car: 2002 Z28
I like that one
Old Oct 27, 2002 | 09:54 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
In all my 3 years of being on this board, I have *NEVER* heard of someone with an 89 or earlier car with a 10-bolt rear end finding 28 spline axles in it. They've always been 26 spline. 1990 cars are a toss up, but 91 and later will definitely have 28 spline axles. Where ever you got your 88 and up or 89 and up information, please update it.
Old Oct 27, 2002 | 08:22 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
You can e-mail SLP (Street Legal Performance) and tell them they need to update their information then. Since they also say it will only work with 89-92 28 spline vehicles...89-90 did have 28 splines though some 89's didn't. My buddy has an 89 Formy with 28 splines...has the SLP differential too. He likes it. Information stays the same, thanks for noting that though Kevin.
Old Oct 27, 2002 | 10:28 PM
Kevin91Z's Avatar
Is that Formula a TPI car? 305 5-speed or 305 automatic? Maybe I should say that I've never seen or heard of a V6 or TBI car with 28 spline axles in 1989 or older.
Old Oct 28, 2002 | 08:08 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Its a 305 TBI manual. Sorry, I should have posted more info. I am gonna double check with him though but I am 99% sure its an 89.
Old Oct 28, 2002 | 06:03 PM
Keith5's Avatar
Car: C1500
My '91 V6 has 3.23 gears. I think all the later model v6's got that ratio. Probably when they went to the 3.1 engine. So that would be 90-92.
Old Oct 31, 2002 | 11:55 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
i have 89 10 bolt in a 305 L03 RS camaro. 26 spline? toss up?
question is, how much is involved in changing the axels, price and time wise? a shop would charge... ?
Old Nov 2, 2002 | 05:14 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
If anyone needs a set of 28 spline axles, let me know. I'm doing some trading this next weekend and am getting a set of 28 spline axles in the trade.
Dan
Old Nov 3, 2002 | 03:01 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
I will, if my 10 bolt has 26 spline axles...
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
