intake manifold gasket leaking
Old Oct 28, 2002 | 08:00 PM
burnouts4ever's Avatar
my intake manifold gasket is leaking antifreeze? could this mean that antifreeze is mixing into my oil??its leaking down the front of the engine.
Old Oct 28, 2002 | 08:23 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
just replace the gaskets and give it an oil change to be on the safe side. If the oil looks like a chocolate milk shake then coolant is making its way intot he crank case.
Old Oct 28, 2002 | 08:51 PM
TBI305Camaro's Avatar
you should definetly change the oil after the intake gasket swap anyways because 9 times outta 10 your gonna get antifreeze in the oil when you do it.
Old Oct 28, 2002 | 09:03 PM
on a 1-10 scale how hard is this job? any tips you have for me, i have never done this.
Old Oct 29, 2002 | 10:15 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
depends on how experianced you are... I'd call it a 3. Just don't forget to torque the bolts down in the right order to spec (30 lbs if I remember correctly ???). Clean the bolts and chase the threads before you do so it'll be right and don't use threadlocker or RTV on the bolts! I've seen so many people screw it up that way. DO NOT OVERTIGHTEN! It will shred the gaskets at the front and back. As for tips... it's a whole lot easier to set the intake back on and center it with 2 people working (one on both sides).
Old Oct 31, 2002 | 07:59 PM
Car: 88 Camaro SC
Engine: SFI'd 350
another thing to make the gaskets stay is two small dabs of super glue in a non critical spot, keeps the gaskets put while you drop the intake on.
Old Oct 31, 2002 | 08:05 PM
Car: 88 Camaro SC
Engine: SFI'd 350
all in all id say it would take around 2-3 hours, maybe more if its your first time doing this. The easiest way woudl be to take off the whole intake with everything (or as much as possible) attached. that way you dont create any more unnecessary work for yourself.
Old Oct 31, 2002 | 09:18 PM
its not bad at all you will figure it out...I didnt even use a torque wrench on mine and never had problems. dont go breaking a 1/2 inch rachet or anything tho.
Old Nov 1, 2002 | 12:42 AM
Car: 88 Camaro SC
Engine: SFI'd 350
even though you could probably get away with out it. use a torque wrench so you get uniform pressure ont he gaskets. Otherwise, they might not even seal if the torque isnt right on each bolt.
Old Nov 1, 2002 | 12:49 AM
mrbboy's Avatar
THis is not a difficult job at all. Just make sure you label everything. I used masking tape and a marking pen. Clean those mating surfaces really well. Don't forget to mark the distributor before you remove it. Get a timing light as this will make adjusting the timing easier later on. Take your time and you shouldn't have any problems.
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
