recomend some 1.6 Rockers for my setup
Old Nov 19, 2002 | 07:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
This is what is going on this winter
LT4 production cam
S/R Torquer heads
Custom chip
New roller rockers???
I want 1.6 rockers to get the advertised specs out of the LT4 cam. Which ones work well with our cars. Do we need self aligning? I know I need a 3/8" stud roller setup. Also do I go with steel or aluminum? I do not need the best but just some good durable ones. here is what i was looking at on summit, CCA-1418-16.
Description says - Chevrolet: 1987-up 305, 350 with self aligning, 3/8 in. stud, 1.6 ratio, chromemoly, roller tip rockers
Any other suggestions. Also, I am concerened that I will not have enough valve cover clearence. Will this be an issue. Money is tight obviously for I just spent on this stuff so new valve covers are down the road. My mods are in my sig if that helps decide.
Old Nov 19, 2002 | 11:51 PM
NJ SPEEDER's Avatar
as long as they say self aligning ithey will work
later
tim
Old Nov 20, 2002 | 12:03 AM
Slade1's Avatar
I just read this post recently... worth following...
https://www.thirdgen.org/techbb2/sho...hreadid=144576
The base of it is that he has some gold rocker arms and its pretty much suffering from metal fatigue, one of the symptoms the rollers are producing shavings from friction under stress.
I personally have comp cams magnum roller tip 1.6 rockers. Pretty good stuff. Stronger than my stock for sure.
Old Nov 20, 2002 | 12:46 AM
Redline's Avatar
Car: 88 camaro SC
Engine: 305 t.oilet b.owl i.njection
Transmission: rebuilt 700r4
what about lunati 1.6 aluminum rockers (theyre blue if that helps anymore)
are these anygood, or are they just as good as any other aluminum rocker?
Old Nov 20, 2002 | 07:07 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Slade,
I just recently read that post as well, and that is why I am leaning towards steel. I was also looking at those magnum rockers. They are 191 bucks but I think they will work great.
Old Nov 20, 2002 | 06:06 PM
fastredtruck's Avatar
Car: 88 gmc 1500
Engine: 496
Do the s r torquer heads have guide plates? If they do you dont need the self aligning rockers.
Old Nov 26, 2002 | 06:06 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Shifty,
Depending on the money you want to spend, I would use either the Magnum 1.6 roller tip from CompCams or, for full roller, I use the Crower Stainless Steel rollers. Both are steel, are rebuildable and last longer than the aluminum ones. No metal shavings. Since they are steel they don't need to be as thick either so they'll fit under the stock valve covers. I have 8 of the Crower's if your interested in running a split set. You'll need guide plates with them since they are not self-align.
Old Nov 27, 2002 | 12:51 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I don't know if what happened to mine was a freak occurance, but for $300 the bearings should damn well stay together.
I just bought a set of Comp Pro-Magnums. I've heard nothing but good things about these.
Old Nov 27, 2002 | 01:00 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I decided to go with the Comp Pro-Magnums. I am so happy to hear that I will have ample clearence with these to retain the stock valve covers. Thanks guys and I will keep you posted on the install.
Hotrodboba400
Dec 10, 2019 07:07 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
