305 TPI heads
Old Dec 10, 2002 | 07:52 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
305 TPI heads
ok, my dad is giving me a set of 305 TPI heads, and gonna be soon doing a LT1 cam swap, will these heads help me any, and if so what kind of gains can i expect with the cam and heads, then in a couple of months headers. Thanks in advance,
Kevin
Oh and one other thing will these heads bolt up with no problem.
Old Dec 10, 2002 | 10:36 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
305 tpi heads will help you a little.. i asked this question awhile back and from the knowledge i got is that with a little exhaust side porting .. prob about 10 hp differance or so with just the heads. with the cam swap prob about a total of 30-40 estmiating. it also depends on what rockers you are using. if you went with roller tip ones like i did 1.52 or 1.6 you would get a tad more than that.
good luck..
Old Dec 10, 2002 | 11:33 AM
Engine: 383, L69
i dont know if this matter or not, but the head casting number is 14101081, its a standard port head, what about these, now
Old Dec 10, 2002 | 12:57 PM
iroc22's Avatar
081 is the most common 305 TPI head; after 87. They're a good basis for a higher horsepower motor over the stock 187s. Just port the intake runners a bit, improve the line of sight in the exhaust ports and put some higher lift springs for the new cam.
Old Dec 10, 2002 | 01:51 PM
NJ SPEEDER's Avatar
adn don't forget a good valve job. the guys in the fastest street car association have proven in teh cheap street class that a low lift(limited to .490 at teh valve) stock casting(not allowed to mess with the head casting at all) can benefit greatly from a good valve job.
later
tim
Old Dec 11, 2002 | 03:33 PM
Engine: 383, L69
can i change the heads with the motor still inthe car or do i need to pull the motor
Old Dec 11, 2002 | 04:21 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
Hey it's me ive been gone for a while but im back now. Any way you can leave the moter in the car.
Old Dec 11, 2002 | 08:19 PM
bbtaz97's Avatar
Car: 91 RS
yes you can do a cam and heads swap with the motor still in the car.
BlueIroc-Z
Jun 9, 2019 03:22 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
