Which Summit Open Air for '89 TBI IROC
Old Dec 16, 2002 | 09:39 AM
MX265
Guest
Posts: n/a
Summit has a few different Open Air Cleaner selections. Can someone tell me which part# to use for my '89 IROC with TBI? It is the 305 L03.
Thanks,
Andy
Old Dec 16, 2002 | 12:14 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
any drop base open element for a 4bbl carb will work for the tbi with a 14x3 air filter
Old Dec 16, 2002 | 12:31 PM
MX265
Guest
Posts: n/a
The description on the one that I am looking at is:
"Vendor: Summit Racing Equipment
Product Line: Summit Chrome Air Cleaners
Material: Steel
Finish: Chrome Plated
Height: 3 3/4 in.
Diameter: 14 in.
Air cleaners with Summit written all over them
14 in. diameter, chrome, with Summit logo, air cleaner
This Summit chrome plated steel air cleaner has a 14 in. diameter, a 3 in. open element, and a flat base. It fits carburetors with 5 1/8 in. neck."
From what I have read on 3rd gen forums here, it needs to be a 14X3 NON-drop base. I was wondering about the size of the TBI neck. Does the TBI have a 5 1\8" neck?
Old Dec 16, 2002 | 02:26 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
yes that neck size will fit i use a drop base on my 89 formula 305tbi with no problems
Old Dec 16, 2002 | 02:35 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
they say to use a drop base because it fits better. you know that spacer between the throttle body and the air cleaner assembly? well, if you get a flat base one, you just dont use that spacer. if flows better than a drop base one does, so if you think you can fit it, then go for it.
i have the flat base on my car, but nothing on mine is stock, so im not sure if it will fit a stock L03.
-brian
Old Dec 16, 2002 | 02:40 PM
MX265
Guest
Posts: n/a
Thanks for the repsonses. That helps. I will go ahead and order a drop base one.
BTW, Z28 Boy, I notice you're in North Syracuse. How's the Weather up there?? I used to live in Liverpool for 27 years till I moved to the Atlanta area.
Thanks,
Andy
Old Dec 16, 2002 | 02:56 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Thanks,
Andy
oh..well, you know the deal. it's been pretty crapy so far this year. it's been cold, and we've already had a lot of snow compared to past years, so it looks like this winter may be a killer. last winter almost broke a record for the LEAST snow ever, so it looks like we are going to make up for it this winter.
this summer, we almost set a record for the hottest summer on record. we had a LOT of over 90 degree days. go figure.
but hey, what do you expect...it's syracuse, where it can snow in the morning, and you can go swimming at night.
-brian
Old Dec 16, 2002 | 03:15 PM
MX265
Guest
Posts: n/a
Glad to see it hasn't changed. Thanks again for input and drive safe in that 2 feet of snow.
Andy
Old Dec 16, 2002 | 04:32 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
why didnt you order a flat bottom
Old Dec 17, 2002 | 05:40 AM
MX265
Guest
Posts: n/a
Because according to the info here, the drop base works. Is this not the case? If so, I better make a phone call.
Old Dec 17, 2002 | 02:35 PM
you are right, the drop base does work......
the flat bottom is better. i would get the flat bottom. you have to remove the air filter spacer/riser, which is good.
basically get the flat bottom
Old Dec 18, 2002 | 07:25 AM
MX265
Guest
Posts: n/a
OK, I am returning the drop base and ordered a flat base. Thanks for all the input.
Old Dec 18, 2002 | 09:51 PM
i think it will be better in the long run, not gonna give you an extra 25 HP over drop base tho...
Old Dec 30, 2002 | 07:14 AM
MX265
Guest
Posts: n/a
OK, got the air cleaner installed. Looks and sounds awsome. A little faster response too. But one minor problem. The air cleaner bolt is on it's last thread and barely screwed in place. I don't want to swap out the 3" element for a 2.5", so does anyone know where to get a little longer air filter bolt that is bent for the TBI, or do I have to make one?
Any input is appreciated.
Thanks,
Andy
Frozer!!!
Jan 19, 2024 04:55 PM
wruiz
Aug 13, 2015 09:07 PM
mustangman65_79
Aug 11, 2015 03:17 PM
92purpz28
Aug 11, 2015 02:30 PM
