how much power will i have??
Old Jan 3, 2003 | 03:04 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
here is my car, can you give me a clue about the horses and torque? it has 181k miles but is getting basically rebuilt with these mods...
91 bird,
305 tbi
lt1 cam
tpi heads, shaved 30/1000ths
3" straight pipes with borla 2 chamber mufler
emissions delete...... (yay)
stage 1 performance chip
hedman hedders
the end for now.... thats how my baby will be in 3 weeks... yay im hoping for a massive improvment over my 1990 3.1 bird ... massive
Old Jan 3, 2003 | 05:47 PM
NJ SPEEDER's Avatar
no way to give an accurate estimate until peopel start putting similar build ups on dyno's. one thign i woudl suggest si skipping the "stage 1" performance chip. data log teh car and get a proper chip burned.
later
tim
Old Jan 4, 2003 | 01:14 AM
92 z28's Avatar
i agree with nj speeder on the custom prom, especially since you are doing cam. pre programed chips for mods that you are doing wont operate at its full potential. im going to give a rough estimate on HP but dont quote, id say between 240-270 horses. good luck man! you should think about a performer intake as well.
Old Jan 4, 2003 | 09:23 AM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
sounds like good choices definitly go with a performer tbi intake though and definitly headers if you havent done so
Old Jan 4, 2003 | 12:22 PM
92 z28's Avatar
how are you so sure about the performer intake mike (firebirdpl)? we hhavent installed yours yet. :lala:
Old Jan 4, 2003 | 01:27 PM
NJ SPEEDER's Avatar
do you know what year LT1 cam it is? they change the exhaust lobe a bit to get an extra 10hp from the LT1. i think teh 93-95 cams are similar and then teh 96-97 cams have teh revised/higher lift exhaust lobe. i woudl think if the heads have a mild port and polish adn a valve job it is not unreasonable to say you can see power in teh area of a stock LT1 with that set up once it si all tuned in.
later
tim
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
