Holley Throttle Body Replacement
Old Jan 7, 2003 | 08:42 PM
Yoda's Avatar
Will the 670 cfm 2-bbl GM TRUCK TBI part number 510-502-5 in Jeg's work as a direct replacement for my TBI unit in my 1991 Camaro RS 305 TBI?
Old Jan 7, 2003 | 10:08 PM
NJ SPEEDER's Avatar
for a 1991 it is not exactly a direct bolt in. all you need to do is switch your wiring harness over to teh older style of throttle position sensor connector. jsut go to your local salvage yard and get a TPS connector that si the 3in a row(bar style) from any gm vehicle. the wires are teh same color, just cut off your stock connector and match up the colors and you are done.
later
tim
Old Jan 8, 2003 | 08:39 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
is that the one with the 2 inch bores? also how much is that one?
Old Jan 8, 2003 | 03:53 PM
Yoda's Avatar
Will the computer freak out at the change? ANd will my current fuel pump send enough fuel? How do I recognize which connector is the TPS connector? Will all other connections match up?
Old Jan 8, 2003 | 03:54 PM
Yoda's Avatar
oh and yes i am referring to the one with the 2.0" bores. It is 335.99 in Jeg's
Old Jan 8, 2003 | 05:32 PM
NJ SPEEDER's Avatar
the stock pump and ecm will be fine. it is a bar looking connector that gm used for years. i has 3 wires and is on teh passenger side of the tb.
later
tim
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
