What would cause my injectors to do this?
Old Jan 12, 2003 | 11:35 AM
Raptor Pilot's Avatar
I pulled the air cleaner assembly off and had someone try to start my car...I noticed that the car was trying to start every time, but that the injectors weren't firing when the car wouldn't start...so my problem is that theyare only spraying once out of every two tries----think it's my fuel pump or my filter? Am I on the right track here? Thanks.
Old Jan 12, 2003 | 01:31 PM
Berlinetta's Avatar
What does the fuel spray look like when it comes out of the injector? Does it look real weak or does it look like a good strong spray?
Old Jan 12, 2003 | 01:46 PM
I'd have to say it looks strong.
Old Jan 12, 2003 | 01:54 PM
Berlinetta's Avatar
Okay, if the injectors aren't firing when you try to start the car most of the time but when they do fire they spray pretty good, then im thinking you might have a crappy connection somewhere. How often do the injectors not work then work?
Old Jan 12, 2003 | 03:21 PM
it's actually very random with no apparent pattern...
Old Jan 12, 2003 | 07:50 PM
JPrevost's Avatar
Car: 91 Red Sled
Re: What would cause my injectors to do this?
Or your fuel pump relay.
Old Jan 13, 2003 | 12:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
bad module or weak pickup coil in the distributer will do the same thing.
Old Jan 13, 2003 | 12:39 PM
Berlinetta's Avatar
forgot about the fuel pump relay
Old Jan 13, 2003 | 01:10 PM
TBI305Camaro's Avatar
I second the ignition module. Pull it off and have it tested. If its good you could try the pickup coil but its a PITA sorta. You have to pull the distributer and take it part.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
