Throttle body swap
Old Jan 21, 2003 | 07:44 PM
MericanMuscle's Avatar
Throttle body swap
Im swapping out my stock throttle body base for a turbo city one on my lo3.. I know i have to take off the gas cap to relieve teh pressure and unhook th computer, then fuel lines and the vacuum hoses and linkage on the throttle body itself.. but my question is what, if anything, needs to be swapped onto the new throttle body base from the old one. I know the the injector pod needs to be , but is there anything else.? Also about how long does it take to do this swap?
Old Jan 22, 2003 | 01:12 AM
vjo90RS8's Avatar
Car: 2002 Z28
if the turbo city TBI does not come with all the sensors, you will need to swap those. Just make sure the TBI you are putting on has all of the same parts as the one you took off, easy as that, but be careful with the throttle position sensor bolts, they break very easily.
Old Jan 22, 2003 | 08:25 AM
Alright thanks, i figured it was going to be somewhat an easy job.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
