How to find out what gears are in ur rearend
fidn teh RPO sheet in your truck. it is the list with all the little 3 digit option codes. if you have 3.73's one fo the rpo's will read GT4. a lot fo gm truck have them in teh glove box.
later
tim
later
tim
Car: 91 Red Sled
Mark the tire and the driveshaft with some chalk and count how many times it rotates against either 1 rotation of the driveshaft (neutral of course) or 1 rotation of the tire. Depending on which you turn and which you count rotations you'll be able to figure out the ratio.
ambainb
Apr 25, 2016 09:21 PM
