Which Cam is best ?
Which Cam is best ?
I just pick up a 1990 RS with a blown motor. I have a stock LO5 out of a 93 C1500 with 70,000 miles. I have two cams to chose from now a new in box Crane Energizer 272 H10 hydraulic (216*216* 110 454*454*)and a used LT1 cam. I was looking at the Vortec heads and TBI intake from Scoggin & Dickey.I was also looking at the ZZ4 cam.What would be the best choice?. This car will never see the track street car only(I have a 70 RS for the track).I have everything to burn my own chips with some experience doing so.
Thanks Mike
Thanks Mike
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
if you got the stuff to burn your own chips i would do the zz4 cam. it is a roller cam, so you need lifters......
