Throttle Body Spacer
Old Jan 30, 2003 | 12:00 AM
fadetoblack's Avatar
Car: 1990 Formula
Engine: 383 Stroker
I own a 1990 Pontiac Firebird Formula. It still has the stock 305cid TBI engine. I am preparing to order the Holley part # : 502-5 670cfm Performance Throttle-Body Assembly and the Holley part # : 300-66 Weiand Stealth Intake Manifold. Should I add a spacer between the manifold and throttle-body assembly. Can you please tell me if this is necessary or if it would be beneficial? If the answer is 'Yes', can you tell me exactly what to get. I know that Turbo City sells a couple of different ones. Please give me some suggestions. Thank you for any help you can give me.
Old Jan 30, 2003 | 12:27 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
What other mods do you have?
Old Jan 30, 2003 | 01:44 AM
JPrevost's Avatar
Car: 91 Red Sled
If you've got room for one and you don't pay too much, go for it. Nothing wrong with them. Just try and baseline performance and gas milage before and after, so you can justify your investment. So far I've only seen spacers work well on stock manifolds or other engines that have too small of an intake versus the rest of the motor.
Old Jan 30, 2003 | 11:38 AM
Engine: LS7
I was thinking the holley T/B is a bit much for a stock 305 or one with bolt ons.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
