Headers add 30hp?
Old Feb 10, 2003 | 08:45 AM
CrispyClutch's Avatar
Headers add 30hp?
I've heard that just replacing the stock manifolds with for example hooker headers is good for usually 30hp?? This true?!
Old Feb 10, 2003 | 08:49 AM
vjo90RS8's Avatar
Car: 2002 Z28
probably on a high output engine, but not on ours. You will see a good gain though, definately worth the money.
Old Feb 10, 2003 | 10:00 AM
1989camarorsrs's Avatar
headers+catback exhuast+highflowcat=25-30hp
Old Feb 10, 2003 | 11:55 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
dont run a cat, and you will prolly not see those gains on an otherwise stock LO3
Old Feb 10, 2003 | 01:22 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Yes headers on a LO3 are worth a lot of hp. I picked up 5 mph and .6 sec with headers and a 3" cat.
Old Feb 11, 2003 | 01:46 PM
MericanMuscle's Avatar
If you were to change your headers and exhaust on your lo3 over to 3inch everything you will see a better gain than on the high output engines with the same exhaust setup, since the low outputs got the crappy exhaust manifolds and 2 1/4 exhaust.
Chad Speier
Sep 24, 2015 12:32 PM
gta892000
Sep 16, 2015 12:37 AM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
