carb manifold
Old Feb 24, 2003 | 08:05 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
carb manifold
i was looking at my friends four barrel carb manifold and his two barrel carb adapter that the barrels of my experiment tbi line up to and i was just wondering why couldnt you buy an egr four barrel manifold and the adapter and drill the holes for the tbi to bolt up to the spacer since the carb manifolds flow more and there are alot more different models of them
Old Feb 24, 2003 | 09:34 PM
steve8586iroc's Avatar
I think you just figured out what most everybody on the board is doing. Glad you could join us.
Steve
Old Feb 24, 2003 | 09:37 PM
Engine: LO3 and LT1
ok so now that im filled in on that does it work because other thatn the other stuff i mentioned they are cheaper on the pocket
Old Feb 24, 2003 | 09:39 PM
They work as good as or better than a tbi specific intake.
Old Feb 24, 2003 | 09:41 PM
Engine: LO3 and LT1
so do you have any pics or anything that i can look at to see how its done
Old Feb 24, 2003 | 10:02 PM
Here's a couple
Old Feb 24, 2003 | 10:04 PM
here's the last one.
Engine: LO3 and LT1
how well does that clear your hood
Old Feb 24, 2003 | 10:09 PM
Engine: LO3 and LT1
that looks bad *** i have to get my headers painted before installing them what kind of paint did you use and is it still on there if the engine is already in the car
Old Feb 24, 2003 | 10:11 PM
I don't know, it's still on the engine stand. Realy though I know it won't. I'll have to go to a cowl hood or make my own hood scoop.
Steve
Old Feb 24, 2003 | 10:13 PM
I put a thermal coating on them it's not paint.
Old Feb 24, 2003 | 10:16 PM
Engine: LO3 and LT1
one more thing what brand of spacer did you use and thanks for the help i have been thinkin on if this would work for like 2 weeks now and i knoow someone who works at a chroming place where i can get my headers powder coated so im lookin into that and again thanks for the help mine will be done before too long
Old Feb 25, 2003 | 06:11 PM
Due to using a 454tb on a square bore intake I had to use a spread bore to square bore adapter then a home made tbi adapter plate. If you look real close you can see both on top of the manifold.
Steve
Old Feb 25, 2003 | 10:35 PM
Engine: LO3 and LT1
the one i was lookin at was from a square bore to a 2 barrel it had the holes in it just like the tbi manifold but was for a 2 barrel carb so the bolt holes werent the same also is yours a 305 or 350
Old Feb 26, 2003 | 04:17 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
How did you get that tb too shine like that. What did you use on it
Old Feb 26, 2003 | 05:03 PM
The engine is a 350 Vortec out of a "96"Tahoe. As far as the tb goes I just cleaned it real good in a can of carb cleaner the sprayed it with chrome spray paint. I don't think it will looK that good after it's been in the car for very long, any gas that gets on it will probably wipe it out. I didn't think about it at the time but I might have to use the techline coating that I used on the headers to keep it looking that good all the time.
Steve
Old Feb 26, 2003 | 09:47 PM
Car: 89 Camaro RS
Engine: 355 TBI
When the gas hit's that tb do you think that the paint will come off and get into your moter. I hope not that could cause you some problem's
Old Feb 26, 2003 | 09:52 PM
I didn't paint the throttle bores, even if I did it's not likely it would hurt anything, it would just get burned in the combustion process.
Steve
Old Feb 28, 2003 | 03:27 PM
Engine: LO3 and LT1
what did you make your spacer out of and also how hard was it to drill the holes acurately any pointers thenks
Old Feb 28, 2003 | 05:49 PM
It's made from 1/2' aluminum plate, my father bored out the holes on his lath. As far as doing this a home you might have to use a different method. You could probably buy one cheap enough that it wouldn't be worth spending the time to try. I believe Tas had a source on them with a price below 20 bucks.
Steve
Old Mar 1, 2003 | 11:08 AM
super chevy's Avatar
Here's a pic of my carb manifold with tbi.
SC
Old Mar 2, 2003 | 12:02 PM
Engine: LO3 and LT1
i know you dont have to worry about hood clearance but how much higher does that manifold make your tbi sit and what were the gains you got from that plus what manifold did you use and also how did you buy/ make the spacer thanks
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
