Slumming it...
Old Mar 6, 2003 | 09:46 PM
vrooom305's Avatar
Slumming it...
Due to increase in gas prices I'm thinking of switching from 91 octane to 87 octane. Will this F'up my engine?
Old Mar 6, 2003 | 10:00 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Pull down your timing to 0* advance and you should be a-OK, esp if you're running the stock chip with stock heads/cam/intake. I used to run 87 when the old wallet was empty
Old Mar 6, 2003 | 10:07 PM
vrooom305's Avatar
What is the stock timing (you are talking about the distributer right)?
Old Mar 6, 2003 | 10:13 PM
vjo90RS8's Avatar
Car: 2002 Z28
how much is gas there by the way, its about $2 even for 87 octane at Chevron, stupid california, oh well, at least it isnt snowing
Old Mar 6, 2003 | 10:17 PM
vrooom305's Avatar
$1.89 - $2.00 + for 91 octane
Old Mar 7, 2003 | 12:39 PM
uk89camaro's Avatar
$5.50 in the Uk for 95 (base) around $5.90 for 97 (super)
Just thought I'd share.
Old Mar 7, 2003 | 01:21 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Unless you have some insane compression or something, you won't need to do any timing crap to run 87 octane gas. Your car has a computer that thakes care of that for you (that's what the knock sensor is for). The only time 87 won't cut is is if you are somewhere near 10.5 or 11 to 1 compression. Read CHP, Hot Rod, Car Craft, Motor Trend, most new cars are designed for 87 octane fuel and some of the engine build-ups are running 87 octane gas. I used to run 85 in my old Firebird and it did just fine. The only reason I run 91 in the GTA, is because it is cleaner and less likly to clog an injector, but a good fuel filter will solve that little SNAFU.
Old Mar 7, 2003 | 05:41 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
if you do the math it doesn't seem that bad.
I can't remember the tank size on the 3rd gen but I remember it being SMALL...
...so assume 15 gallon...
15 gal * 1.89 = 28.35
15 gal * 2 = 30
You're saving a whole $1.65.
I have a 27 gallon tank. I'm already pumping $30 of gas into it at a time...I figure another dollar or two for the good stuff...I'm not even going to notice it.
okfoz
Oct 13, 2015 02:19 PM
85cmroz28
Oct 4, 2015 09:44 PM
luvofjah
Sep 26, 2015 08:28 PM
CORV3TT3
Aug 23, 2015 11:26 AM
CD MaroMan 91
Nov 28, 2001 04:45 AM
