TBI intake pic needed
Old Mar 9, 2003 | 09:27 AM
vwdave's Avatar
I have a very poor memory.
I am doing the motor on my 305 TBI. (Converting to a 350.)
Well, its going back together, but I have a bracket that I dont know where it goes. Can someone take pics of their intake for me? With the air cleaner assembly completely off and somewhat close pics. I am going to use it as a referece to get that bracket in the right place and get the vacumn lines back on right.
TIA.
Old Mar 9, 2003 | 04:42 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
This isn't a very good pic for what you want, but it's a start, did you try a search. In this pic the brackets for lifting the engine are gone and I relocated the "heater valve?" towards the back. The one plugged vacuum line is the one that goes to the heat stove valve.
Old Mar 9, 2003 | 04:46 PM
vwdave's Avatar
Can you get one REALLY close up on the passenger side? Like, 2' away? The bracket is nowhere in the chiltons book. I can find the vacumn crap in chiltons though.
Old Mar 9, 2003 | 05:13 PM
Engine: LS7
I have no brackets on the pass side, There was a engine lift bracket there with 2 holes in it and there's a little electrical connector with vacuum lines coming in and out, one goes to the EGR, mine is just lying there though, no bracket.
Old Mar 9, 2003 | 05:23 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Can you describe what it looks like or post a pic?
I just re-installed my motor and may be able to identify it.
S-D
Old Mar 9, 2003 | 05:28 PM
vwdave's Avatar
I'll have to do that tommorow.
Old Mar 9, 2003 | 07:09 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
There is a bracket on the passenger side that holds the EGR solinoid. Is that what you need a pic of?
Old Mar 9, 2003 | 08:59 PM
Car: 1991 RS
I have a bracket that holds a little vacuum module on the rear passengers side- has two vacuum lines connecting to it (side by side) and one 2-wire electrical connector on the opposite end.
It mounted on a small braket that mounts to the rear hoisting bracket.
This wouldn't work with my set-up so I made my own bracket. I had to modify a lot of my old 305 brakets to fit the new vortec bolt pattern (engine hoist brackets and so on..).
A pic would help volumes---
Best
S-D
Old Mar 10, 2003 | 06:59 PM
vwdave's Avatar
Best
S-D
That was it.
Thanks.
MustangBeater20
Oct 29, 2022 09:20 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
