Intake
Old Mar 14, 2003 | 02:27 AM
S!MON's Avatar
Car: '87 Camaro Z28
Engine: fully loaded 350
Transmission: T5-World Class
Intake
hi,
what do you think?
will this fit on a '90 camaro tbi?
if you could get cold air to it, would it be better than an open element?
I've got my doubts!
greetz
S!MON
Old Mar 14, 2003 | 07:23 AM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
will what fit? No details at all bro... need more
Old Mar 14, 2003 | 12:42 PM
S!MON's Avatar
Car: '87 Camaro Z28
call me ********!
forgot the link
look
that's it!
greetz
S!MON
Old Mar 14, 2003 | 02:24 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
ok ********
i think it would probably "Fit" but i don't how it would work with the contour of our hoods, it might not clear where the element is supposed to go.
i think you are fine with the OE, it should have PLENTY of airflow for even the most stout TBI cars.
Old Mar 14, 2003 | 05:37 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by Dewey316
ok ********
i would not buy that piece. but the OE does not have plenty of airflow for even stock cars, that is wrong. why do so many poeple switch to a open element with good results? even on stock cars. i would go out and buy an open element, hey it works for all the faster carb gusy.....
Old Mar 14, 2003 | 10:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I just snagged an entire extra air cleaner housing for $15, cut another hole in my housing, cut a piece of the snorkel off the extra one, held in place with rivets and JB weld, painted the whole new housing, added flexible hose from Autozone.
Coolant overflow bottle in the way, so I switched to a V6 coolant overflow bottle, and stuffed it under the plastic cover where the hood latch is. Drilled a 2.5" hole with a hole saw to get to the cap, and replaced longer hose to rad cap.
Created a homemade dual snorkel setup for under $25. Cheap, 2 hrs. work, and nice (noticeable) improvement on my otherwise stock LO3.
Old Mar 15, 2003 | 12:48 PM
cashman's Avatar
go with open air dude. not only does it sound better, but the stock setup cant even feed a 4banger with enough air at 4500. open elemnt sounds cooler and you can FEEL the power difference. after i did mine i kept up with a new mustang gt AND i had a broken trnny mount(not bragging, it was a chick and she couldnt shift for ****) no go with open element, drill a hole for intake temp sensor, let crankcase breather filter hang
Old Mar 15, 2003 | 08:03 PM
Charlo's Avatar
"K&N style conical air filter sucks air in from the top
- Mandrel-bend chrome plated aluminum intake pipe allows unrestricted cooler air to be breathed into the engine "
K&N style.... thats not a k&N though. The real deal has K&N stamped in the metal lid ontop. Could be an AFE which does better than a K&N and uses that blue color. I doubt it for that price.
Mandrel bent, tube looks strait to me
Charlo
Old Mar 17, 2003 | 07:15 AM
Dewey316's Avatar
Car: 1990 Camaro RS
by OE i meant Open Element. sorry for the missunderstaning.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
