runs fine til try to restart, TBI
Old Mar 27, 2003 | 11:53 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
delete
thanks
Old Mar 27, 2003 | 11:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: runs fine til try to restart, TBI
Originally posted by Fast68
what in the heck could cause a TBI system to not want to spray fuel at crank and when finally it does decide to it runs perfect until you shut it off and then it wont spray fuel again for a long time when cranking ?
im lost now..
thanks
Could be the ignition module. The ECM fires the injector(s) each time a distributor reference pulse arrives. No DRP, no injector pulse.
Could also be a bad or loose connection in the power feed to the injectors.
RBob.
Old Mar 27, 2003 | 02:57 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i had the same problem for over a year off and on. my solution was simple, CARB (not the only reason i switched)
Old Mar 27, 2003 | 09:19 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
i went all through the distributor today, removed it from engine cleaned it out good and put new dielectric grease under the module and so forth, also totally disassembled the TBI and did the raised platform pressure trick, no dice, still does same thing, it will start spraying fuel at crank eventually when it feels like it and runs fine once it does...
wild,..
Old Mar 28, 2003 | 09:31 AM
CrispyClutch's Avatar
When you get it idling, disconnect the MAP vacuum. If the car settles down and idles (may die once again, just restart) but if it settles down and idles,albeit a bit high, then its prolly the MAP sensor. Just go to Discount auto parts, ask to try a new MAP sensor and theyll let you use it before you buy it,atleast the guys here did,and sure enough thats what caused the problem.
Old Mar 28, 2003 | 09:57 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
I would Replace your fuel filter, It could be a going bad fuel pump. I had a tbi jimmy that you had to pour a little gas in the tb to get it started then it would run fine. So i replcaed the fuel pump. and that fixed my problam.
Old Mar 28, 2003 | 11:35 AM
I'm betting its the MAP.
theshackle
Mar 5, 2017 06:37 PM
apo_bailon15
Mar 28, 2016 05:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
