White stuff on spark plugs...
Old Apr 7, 2003 | 07:57 AM
CrispyClutch's Avatar
I pulled 3 of my spark plugs last night... The conductive parts were covered in a whitish coating. I took some sandpaper and got the stuff off, but it was getting dark and I only got the 1st 3 sparks done. Do you think that coating could be whats making for hard starting?
Thanks.
Old Apr 7, 2003 | 09:53 AM
btw it wasn't carbon.... And this stuff was just caked on.. what could it be?
Old Apr 7, 2003 | 10:17 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
prolly oil ash
Old Apr 7, 2003 | 10:21 AM
I'm guessing thats what could be causing hard starting?
Old Apr 7, 2003 | 10:43 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
yes, it would definetely have a part in it.
Old Apr 7, 2003 | 11:39 PM
25THRSS's Avatar
oil ash?? Ive never heard of that before. Is that caused by running lean?
Old Apr 8, 2003 | 12:09 AM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
Quote from Hayne's:
Ash Deposits
Syptoms: Light brown/white deposits encrusted on the side and/or center electrodes. Derived from oil and/or fuel additives. Excessive amount may mask the spark, causing misfiring and hesitiation during acceleration.
Recommendation: If excessive deposits accumulate over a short time or low mileage, install new vlave guide seals to prevent seepage of oil into combustion chamers. Also try changing gasoline brands.
So if you car burns oil then that's what causing the fouling on the plugs, if it doesn't then it might be as simple as bad gas.
Old Apr 8, 2003 | 10:17 PM
blazer's Avatar
could also be antifreeze.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Jlanz55
Sep 9, 2015 09:09 AM
