Post Your Intake Manifold Pics!!!!
Old Apr 13, 2003 | 01:22 AM
25THRSS's Avatar
Lets see everyones pictures of your intake manifold. Carb intake with an adaptor, tbi intake, whatever, lets see some pictures! The more detailed the better! Post as many as you got. I wanna see em all!!!!
Old Apr 13, 2003 | 06:47 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Edelbrock 2101 intake with a homemade TBI adapter.
Old Apr 13, 2003 | 08:18 PM
25THRSS's Avatar
come on, I know there's more out there.
Old Apr 13, 2003 | 10:17 PM
steve8586iroc's Avatar
Here's you an RPM Air Gap.
Old Apr 13, 2003 | 11:20 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
will that airgap fit under a stock hood or are you using a cowl? i thought i was cutting it close with just the plain performer with 2 1/2" flat-base
Old Apr 13, 2003 | 11:25 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Since everyone else is posting theirs on the stand
Oh yea, performer rpm with the holley adaptor.
25THRSS's Avatar
How are you guys hooking up all the sensors and hoses and fuel lines to the carb manifolds? Is it a lot of fabbing up?
Old Apr 14, 2003 | 12:32 AM
ZRATED's Avatar
Here is mine
Old Apr 14, 2003 | 12:34 AM
ZRATED's Avatar
another
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Zrated, where are you running your heater core feed hose from?
And this is just kinda a general question, would it be ok to run the hose directly off the port on top of the water pump instead of off the manifold? Thanks
Old Apr 14, 2003 | 12:57 AM
25THRSS's Avatar
Any new times for that car zrated? Engine looks good, its so shiny it practically blinds me, lol. How much trouble did you have installing the carb intake manifold? I am really interested in finding out what all needs to be modified to get it to work. Thanks!
Old Apr 14, 2003 | 01:31 AM
ZRATED's Avatar
I have not gone to the track lately im just waiting on my stall an a lil more suspension work. My heater core had a leak so im not running a heater core for now. When u put on a carb intake u will have to change a few things but nofin that u can find at a local hardware store or autozone. The only part that kinda sucks will be mounting the throttle bracket so that everything works on it. I had a lil bit of a problem with that, becuase i had a higher intake an the NOS plate, but once I did a lil bit fabing up i got it all to fit nicely.
Old Apr 14, 2003 | 11:33 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
In response to the fuel lines...
I also had to make a kickdown cable bracket. Instead of the heater core feed coming off the back of the manifold it comes out to the left of the CTS in the above pic.
Old Apr 18, 2003 | 10:15 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
edelbrock performer rpm air gap for vortec heads.
-brian
Old Apr 19, 2003 | 08:30 AM
Dan W's Avatar
My old setup
Old Apr 19, 2003 | 10:59 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
Question?? Has anyone changed intakes and kept the stock EGR and cooling lines setup?? what intake did you use. i notice that there are no egr vavle on these engines. Thanks
Nick
Old Apr 19, 2003 | 12:08 PM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
these are really big, but they are detailed....
its just an edelbrock Performer TBI
Old Apr 25, 2003 | 11:46 PM
25THRSS's Avatar
keep em comin guys. I know theres more out there.
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
