are 305/350 heads similar...
Old Apr 13, 2003 | 11:07 PM
Akshay's Avatar
Are the cylinder heads for the 305 and 350 engines similar?
Edelbrock has 50-state cylinder heads that fit 5.7 engines, but it also says that it'll fit a TBI.
Akshay
89 RS T-5
Old Apr 13, 2003 | 11:21 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Generally 350 heads have 62-64cc combustion chambers as opposed to 58cc (although some aluminium heads for 350s are lower) that the 305 comes with. Plus the 5.7 heads generally come with 2.02 intake valves which you dont see on 305s too often (but they do work!). They'll bolt up fine though, and work ever better if you have them milled to decrease compression
Old Apr 13, 2003 | 11:34 PM
Akshay's Avatar
So it would be a good idea if I changed the lifters, springs, intake/exhaust valves, pushrod, and rocker arms.
You agree?
Akshay
Old Apr 14, 2003 | 06:52 AM
Deemax's Avatar
Car: '89 RS Convertible
Engine: 355
You mean increase compression, don'tcha?
Old Apr 14, 2003 | 10:15 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
I really meant to say decrease the combustion chamber, but yea in that context it should be increase compression. Oof.
Old Apr 14, 2003 | 04:28 PM
Pontiacman's Avatar
Typical 305 heads have 1.75/1.5 valves.
350's have 1.75/1.5 , 1.94/1.5, or even 2.02/1.6 valves.
For the most part the 1.94/1.5 are sufficient giving excellent throttle responce and power. A 305 won't benefit with the 2.02/1.6 because they are too close to the cylinder walls, therefore ristricting air flow. The 1.94/1.5 will give lots of power on a 305, but harming the throttle response a bit at low rpm.
Old Apr 15, 2003 | 08:50 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
I thought the stock intake valve sizes on a 305 were 1.84's.
Old Apr 15, 2003 | 09:41 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
heads
So a set of 95 Truck 5.7 TBI heads will fit just fine on my 305 TBI
thanks guys
Old Apr 17, 2003 | 07:14 AM
jlbolin's Avatar
my cousin has a 84 or 85 camaro with the lg4 im not sure if they are the stock heads but on intake they are 1.84.
Old Apr 23, 2003 | 03:40 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I suggest not putting 350 heads on a 305 it lowers your compression and does a whole lot extra. Before I put in a L98 cam and heads. I lost ALL my power my car was slow as hell. I had absolutly no low end power (so little that my car bogged off the line) and the top end wasnt even all that great.
I later changed over to monte carlo SS heads (305 motor) and all my power returned...atcually a whole lot more power came with it.
Old Apr 23, 2003 | 04:03 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
About the only heads that had 1.72" intake valves where the G0D awful late 70's-early 80's SMOG heads.
Those heads should be thrown overboard at the local sandbar to keep you from drifting off while you down a few.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
