New manifold installed today......and a problem
Old Apr 17, 2003 | 07:16 PM
The Greek's Avatar
Car: 70 Nova SS
Transmission: TH350
Today was new intake manifold day. I put a Edelbrock Preformer Manifold (for a carb car) on my 92 RS automatic, with the original TBI. It seemed like everything was going to be fine until I started it back up. With everything hooked back up the car now idles at 2000 RPMS, and when I put a load on it (Drive or Reverse) the engine takes a huge dive down to 500RPMS and struggles very hard to stay alive making it virtually impossible to drive. After about 5 seconds of being in gear, the car sputers and dies. Also, when shifting in to drive, it SLAMS into gear, feels really bad......
I have never done any work with the distributor and rotor before. I marked the distributor when I took it off but I think something went wrong when we put it back in. I think that I have a timing problem here......way too advanced?
What do you guys think?
Jason
Old Apr 17, 2003 | 07:33 PM
novadk13's Avatar
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
if the car was fine before i would first check the plug wires are all on then check the timing. My old truck did something like that but it was only a bad wire but it sounds like you may need to check the timing.
Old Apr 20, 2003 | 03:13 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
If it is idleing at 2000RPM, it sounds like you have a vacuum leak, or several. I'd go back and recheck all of your vac hoses. The dist may cause it to run poorly, but would not explain the high RPM idle
rocn7roc
Sep 21, 2021 02:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
transaero
Aug 31, 2015 01:14 AM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
