Timing problems
Old May 15, 2003 | 03:30 PM
dtpmike's Avatar
Timing problems
I had my distributor rebuilt and then he gave me back the car and it was running like crap. It would stall out at idle. I eventually took it back and told him the timing must be off, then he said no it cant be that and spent 30 minutes checking this other crap.
Then I told him to check the timing and he did. He said "You're right it is a little off". It was at 12* advance base timing. Isnt that A LOT off?
I had him put it to about 3-4 and now its fine, but I cant believe he said that 12 was a little off.
Old May 15, 2003 | 08:34 PM
badxs's Avatar
hey buddy 12 degrees is not that far for most motors, 12 is about as far as you should go though, so did that fix it or was it something else?
Old May 15, 2003 | 11:39 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
12* is VERY far off, when the base timing on a TBI is supposed to be 0* with the ESC unplugged.
Old May 16, 2003 | 06:50 AM
dtpmike's Avatar
yeah that solved the problem immediately
Old May 16, 2003 | 09:14 AM
badxs's Avatar
12 may be alot for you but i love the way my car runs at 12, and all older 350's with carbs love 16 degrees witch is about 32 total
Old May 16, 2003 | 09:41 AM
bills82z28's Avatar
Find another mechanic
Old May 17, 2003 | 06:59 AM
JokerRS's Avatar
Car: 92RS
Engine: 357
4*- 6* base timing is about right for stock cam.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
