coolant temp sensor reading
Old May 20, 2003 | 05:25 PM
topher's Avatar
does anyone know what the coolant temp sensor is supposed to be reading when the engin is at normal runnin temp
Old May 20, 2003 | 08:42 PM
badxs's Avatar
well it really depends on the temp the motor is actually running at?? it constantly varies. so what is yours running at?? what ive seen is 195to 230
Old May 21, 2003 | 12:22 AM
25THRSS's Avatar
when driving it should be between the 0 and 220 mark, or 160, and when idling for a while it should reach just above 220 and slowly cool back down to just above 160 once driving again.
Old May 21, 2003 | 05:48 PM
topher's Avatar
not the sensor for the guage, the sensor that send a signal to the computer
Old May 21, 2003 | 06:52 PM
badxs's Avatar
and what did you think we were talking about, does yours read celcius then it would be about90- 112 ive seen
Old May 21, 2003 | 07:52 PM
topher's Avatar
so what are u sayin its supposed to read 90 to 112 ohms. once again there are two censors. one for the guage in your dash the reads engine temp. and another that send a value to the computer. i need to know that value. i'm assuming its open when the vehicle is cold and reads ground when its warm. anyway the problem that i'm having is it wont start when warm, cranks just fine, but smell gasy. the only way to get it to start is if i unhook the injectors and crank it over. yes that means its flooded for u folks from illinois.
Old May 21, 2003 | 07:54 PM
topher's Avatar
and it runs around 120 when cruising down the interstate. but if i let it idle in the driveway it creaps around 220to230 and the fan kicks in and brings it down to about 180degrees
Old May 21, 2003 | 07:57 PM
topher's Avatar
better yet on the intake of your car where the coolant temperature sensor is, yes the one with the black and yellow wires. that means two wires one black whick goes to ground, thru you computer and yellow that send a signal to the computer. go start you car let it get nice and warm, take a multimeter and read between the black and yellow wire in resistance mode. and write back to me the value u read. this would help me alot
Old May 21, 2003 | 08:53 PM
badxs's Avatar
well if you wanted ohms readings why didnt you say so dumb a++
go to alldata to see if you can get the reference chart , i just usually use a scan tool to see the engine temp because its readind the cts for the ecm, not the gauge buttface
eightsixseven
Dec 16, 2024 01:50 PM
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
