would this make much of a difference?
Old May 27, 2003 | 10:58 AM
jcjohnston78's Avatar
current setup. 94 non roller L05 w/ mild cam
im trying to decide if i want vortec aluminum heads or ir i want the stock vortec iron heads.
if i get a set of used iron heads im planning to get my friend to port and polish them. he also said he will match the intake, and tbi at the same time if wanted it (port and polish them as well)
my question is, will port and polish of a stock tbi intake manifold be worth it or should i go ahead and get a carb intake manifold and use the adapter instead?
o yeah i forgot ill be getting the ultimate tbi mods done right before i get the port and polish done.
thanxd
Old May 27, 2003 | 11:32 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
i would get a lighter intake and one that is better i want the performer rpm airgap manifold. i have seen several tests with various manifolds and this one blew the rest away!!! and theres always a but... it may not fir under your hood. which is why i won't get mine untill i get the ss hood with the scoop on it!! the stock manifold is freakin heavy i would trash it!!
Old May 27, 2003 | 01:09 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
On a 350 with a mild cam and vortec heads that stock intake is going to be a huge restriction. I'd say definitely go with an aftermarket intake most likely a carb manifold with an adapter. I would be looking into the Performer RPM or the Weiand 7525.
Old May 27, 2003 | 01:14 PM
thats what i was thinking, but the intake needs to be emission leagal. i really didnt want to spend a lot on the intake. i may go tpi if i find one cheap enough (i know i have to get a custom intake to fit the vortec heads)
will ported and polish open some that restriction on the stock tbi intake?
Old May 27, 2003 | 06:42 PM
BronYrAur's Avatar
Engine: 305 TBI
Yeah scratch that I forgot you had vortec heads when I said those intakes. You're goign to have to shell out the money and get a vortec specific intake, I'm not positive but I don't think the stock TBI manifold you have on the LO5 will even fit the vortecs even if you try to modify it.
Old May 27, 2003 | 06:49 PM
ok i just realized that that i would have to change the intake manifold. so getting the vortec head fairly cheap is so cheap now.
instead of doing vortec heads...what are good set of heads. that are about the same price as of new vortech heads?
Old May 27, 2003 | 07:02 PM
BronYrAur's Avatar
Engine: 305 TBI
The tbi intakes off of 305(LO3) and the 350(LO5) are the same intake but Vortec heads require an entirely different intake; I don't believe the ports even match up.
Old May 27, 2003 | 08:14 PM
yeah i did some research on the vortech with the tbi. so basically i most like wont use the vortec heads. so any ideas about getting set of heads about the same price range of the vortec. any ideas?
Old May 27, 2003 | 09:32 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
You could go with a set of World Products Torquers. As far as porting and polishing, it will help a fair amount. Do not polish the intake side of the heads or the intake ports, if you get the walls to smooth on the intake ports the atomized fuel will bead up on the walls instead of flow right by. So gasket match the intake side and light porting but don't polish. The exhaust side however can be poilshed to glass smooth so can the combustion chamber.
Old May 27, 2003 | 09:38 PM
steve8586iroc's Avatar
Whats your price range as far as heads go?
Steve
Old May 27, 2003 | 10:08 PM
well it was about the price of aluminum vortec....about 300-700
Old May 28, 2003 | 03:55 AM
BronYrAur's Avatar
Engine: 305 TBI
http://www.protopline.com/
Check out the Pro Lightning lineup on that site. The lightnings seem to be a popular choice.
Old May 29, 2003 | 07:51 PM
The only aluminum heads you can get in that price range is a set of used L98 Vette heads. Add about $300.00 to the seven you already have and get a set of Edelbrock E-Tec 170's from Jegs.
Steve
Old May 29, 2003 | 09:41 PM
well, yeah ive been looking into the prices of heads. im probally gonna get the vortecs with the new intake or l98 vettes. if i were to spend more than a grand on set of heads...i could getet my neighbors LT1/t-56 setup for 1500 instead. but then again i just did an engine swap i dont want to do another one this year
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Mar 22, 2019 09:39 PM
onefreakz
May 14, 2018 12:15 PM
tmellott89
Aug 16, 2015 02:58 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
