open element ?'s
Old Jun 1, 2003 | 11:53 PM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
open element ?'s
on the open element what base drop does every one have for a 14x4. and is there a noticeable increase in power
Old Jun 2, 2003 | 02:12 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
its best to use a flat base, that way u can remove the spacer ring which resticts airflow.
Also, i think 14x4 is a little much, especially for a stock hood. I have a 14x3 and even thats cutting it a lil close.
There is some gain, but dont expect too much. I think a functional cowl hood would be great for future consideration, The hot air kills performance.
Old Jun 3, 2003 | 12:10 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
I put an Edlebrock open element on my 90' RS and it required that I keep the spacer ring in. Got it from AutoZone for like $30, looks and works great.
Old Jun 3, 2003 | 04:04 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
I have the same element... the one where yo have to keep the spccer ring/.. i only bought it cuz i thought it was the non drop base! well now i'm having trouble finding the good one! but i would need the bolt extender so i can screw the top! hopefully i'll have it soon!
for right now i'm hapy with my open element drop edlebrock air claner
Old Jun 3, 2003 | 04:20 PM
cali92RS's Avatar
Car: White KSwisses
summit sells the flat-base by itself. I think its like $15.
I dont even think the open element is really worth it if you cant remove the spacer ring.
Old Jun 3, 2003 | 06:32 PM
Car: 1992 Firebird
ok thanks so ill go with the 14x3. thanks
Old Jun 3, 2003 | 06:39 PM
Sleipnir's Avatar
mine came with the long screw post thing, all you have to do is bend it like the stock one and cut off some mine works fine...but the damn nut pops through the heat pad
Old Jun 4, 2003 | 04:58 AM
90RS305's Avatar
Even with the fact that mine still has the spacer ring I noticed instant results, especially above 4,000RPMs. I can go past the red line now and still not lose power, as before right about the 4,000 mark it started to bog down. For $30 you can't go wrong...
Old Jun 4, 2003 | 12:23 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Buy some all-thread and bend it up.
Old Jun 6, 2003 | 02:44 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I bought a 14x5" offset open element from summit with a reusable filter for $45. I also have a 3" cowl hood too but I didn't use the spacer ring. I have maybe another inch to go but I did have to cut off some of the thread on the top. I am considering trying to get a custom made plate that goes under the open air element that will allow me to put foam all the way around the filter (like the old school cars with shaker hoods) and close off the engine bay and let it get the air only from the cowl hood. Does that make sense to anyone?
Old Jun 6, 2003 | 03:40 AM
1MEAN92RS's Avatar
Engine: LO3
Summit, Moroso, and Ram Air Box all make air pans. I believe R.A.B. has one like you want. See my posts in this thread: https://www.thirdgen.org/techbb2/sho...hreadid=163761
Old Jun 6, 2003 | 07:44 AM
HIBERNIS's Avatar
What I did was I bought a K&N fipk cold air intake for a 96 TBI Dodge and routed 4 inch flexible aluminum tubing all the way to the left front fender.
Old Jun 7, 2003 | 05:24 AM
90RS305's Avatar
Well, as I just found out at the track tonight, an open element is only good in 2 conditions: A) You have functional cowl/ram air and are getting cold air to the filter, or B) you live in Alaska where the air is ALWAYS cold. I was running a 15.3 with the stock intake on AND a bad clutch, but it was in Feb. Now I have a GOOD clutch, and my open element, and I don't even want to talk about how bad my car was doing. I live in AZ, go figure. Can't wait to get my SS hood!
Old Jun 7, 2003 | 09:35 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: open element ?'s
as i measured, with a summit DROP BASE air cleaner (the spacer ring must remain on) you CAN fit up to a 3.5" filter. i have a 3" on mine...
i would have prefered the flat base, but i only did the mod because my friend had a free base and top and a 14"x3" element is cheaper then a stock replacement...
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
