For anyone swapping to a high volume/pressure fuel pump
Old Jun 10, 2003 | 07:09 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
There is a short section of rubber hose going from the pump to the sending unit. Make sure to replace it and use a braided sleeve over the new piece. My stock rubber hose lasted about 5 minutes with the Walbro 255 high pressure pump. It may have just been mine, but it's worth it to replace it considering it costs next to nothing.....As opposed to the $200 it cost me to have the tank dropped again
On the upside, my engine will finally be getting the fuel she needs!! I'm hoping to pull 105mph or better in the quarter mile with the 2bbl TBI. I can't wait!!
Old Jun 11, 2003 | 01:13 AM
JPrevost's Avatar
Car: 91 Red Sled
Re: For anyone swapping to a high volume/pressure fuel pump
$200!!! Dude, I'd do it for you in an evening for $40 and beer . (friend next to me says $50... ) . Anyways, I sure hope you get a 105mph or better. My 102mph has been around a WHILE and needs to be beaten bad. Either you do it first or I'm going to go and post a new speed .
BTW, Personal Message me, I can help you go fast without telling you to burn an eprom. I don't want to give this info away to just anybody right now....a few weeks maybe.
Old Jun 11, 2003 | 11:45 AM
Engine: LO3;383tpi
Wow!, It's good to hear from ya Jon, I haven't seen you on the boards too often lately. A little friendly competition always sounds like fun, I'm really interested in seeing you break your 102mph mark with the 350 H.O.
I try to do all of the work myself as it seems like something always gets messed up when I have to bring it in. Unfortuantly, the only thing they don't let us play around with on the lifts we use is the fuel system Oh well, maybe one day when I have a garage, I'll try swapping in a 4th gen fuel tank......
Old Jun 11, 2003 | 08:40 PM
Engine: LO3;383tpi
Update!! Got the car back today, and all I can say is Oh My ***!! An amazing difference! Feels like a completely different engine. I notice the Holley regulator is really touchy when using this fuel pump.....a half a turn on the set screw makes the difference between 18psi to 70+psi. I've got her at 22psi, now for a little chip tuning.... Can't wait to see what she'll run...but for now, the guy that built my engine needs to fix all of the oil leaks. Hopefully I have her back by next friday.
Old Jun 12, 2003 | 07:28 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
11/15/2000
12.49 @ 105.25 MPH
Sorry I beat you to it...
Old Jun 12, 2003 | 10:23 AM
Engine: LO3;383tpi
12.49 @ 105.25 MPH
You made those that time with a naturally aspirated 2bbl TBI? What were/are your mods? 12.49 is pretty nice. Though I'm confident I'll pull 105mph or better, I'll probably only be low 13s on street tires. Of course they just repaved the first 1/8 mile at KCIR, so traction is next to impossible.....I think I'd do better on ice What traction mods do you have?
Old Jun 18, 2003 | 05:49 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
is this with the 305 tbi guys dam thats fast for that engine also could you please type out the up gradded stuff on the305 tbi and what tbi your using and what injectors size and at what fuel pressure also at what psi do you have to stop using a rubber hose and a clamp and switch to steel braded(cant spell)hose with threads right know ive got my fuel return line clamped on to the metal part i had a little over tightening problem.
Old Jun 19, 2003 | 08:32 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
See
https://www.thirdgen.org/techbb2/sho...hreadid=184959
he's using a 4v TBI on a 383, not a 2v. So he's got a big advantage.
You're gonna need the 454 TBI unit if you plan to stay with a single 2v TBI, especially with the 383, and even then it might not be enough cross sectional area.
Staying with the stock 2v TBI will still give you outstanding mid range torque, but you will be choked at high rpms, and the tbi will be the weak link. It will never keep up with the heads/cam/displacement. So you either have to go with the 454 TBI (or the big Holley 2v) or duplicate what FRMULA88 did.
Dual 2v TBI would also solve your problem but you'd need to deal with the injector driver amps (which has been discussed elsewhere on 3rd gen).
Old Jun 19, 2003 | 12:05 PM
JPrevost's Avatar
Car: 91 Red Sled
Sounds a lot like the pressure regulator spring bottoming out to it's full compression height. I had the same problem, 18psi was where it stopped. So I installed a spring I aquired from my friends father over at Princeton University. Now I've got 28psi as my min setting and it runs GREAT!! Going to the track tomorrow, I'll scan in the times and post. I can promis 13.6 at 104mph but I hope to do much better than that.
Old Jun 19, 2003 | 01:50 PM
Engine: LO3;383tpi
I can't wait to see what you run Jon! It's been a while since you ran the 13.8@102. I know we have been looking foward to you running her again for a while. I'm hoping to make it to the track a week from friday, with a new chip and hopefully some rubber. Is there any chance of aquiring another one of those spings?
I'm running the Holley 670 polished w/ 85pph injectors, 1/2" tbi to carb adapter, and an injector pod spacer. I can tell you that it is not even close to big enough 4 my engine. She breaths to around 4,500rpm, then starts to run out of air. The engine, given enough air flow will make power to 5,500rpm. So yes, a 4bbl tbi will be going on there. For the time being though, 105mph is my goal with the 2bbl tbi.
Old Jun 19, 2003 | 09:38 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Im gonna order a 255 tomorrow thanks to this thread Im pulling 13 psi with stock injectors on my combo, which is why I think Im not getting nearly the traps I think is in the damn car. The pressure falls under a load, which makes it even worse.
Keep us updated, both you and Jon
Yep, dropped $113 on it today, lol. I hate my car.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
