Would this be a good buy
Old Jun 15, 2003 | 05:08 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
okay it says 375 horsepower fom a TBI 350 engine so would you buy it let me know.Also would i have to use a 454 TBI to use this or i was thining about using a TPI system on it/
HERES THE LINK
http://cgi.ebay.com/ebaymotors/ws/eB...category=33615
Old Jun 15, 2003 | 06:40 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Tough call on the power levels. He's basically running a 350 with a zz4 cam and worked over vortec heads. A stock zz4 only makes 355 hp with a carb setup, running 10.1:1 compression. So I doubt that it makes 375 hp with a tbi setup. Plus he has never dynoed it to prove the power. So it's probably an estimated guess. It looks like a nice setup though, I would run a holley 670 tbi on it and get rid of the gm tbi intake and put on a rpm air gap intake or something equivalent.
Old Jun 15, 2003 | 06:53 PM
pat12spe's Avatar
I saw that puppy on ebay myself and fell in love. It does look like a pretty setup but I agree with 89fastlookinrs. He should put some dyno specs up to validate his claims. It would look good in the car.
Old Jun 15, 2003 | 07:34 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Do yall think it's emissions legal?
I don't know though, $2500 for a rebuilt motor? . . . not all new?
Old Jun 15, 2003 | 10:58 PM
vjo90RS8's Avatar
Car: 2002 Z28
is that a roller block/cam?
Old Jun 16, 2003 | 12:17 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
It's the ZZ4 cam, so it is hydraulic roller. The engine seems like a pretty nice set up, and $2,500 is not bad at all for a long block with those internals and power numbers. Realistically speaking, I'm not to confident it's really kicking out the 375 hp he's claiming, especially w/ a two barrel tbi, but there should definetely be some good power. And the only reason I doubt the 375hp is because, as far as I know, it has yet to be proven with a 2bbl tbi. IMO, even if it's only going to get you 330 hp, it's a pretty good deal considering it comes with the intake and hyd. roller cam, and machined heads. Just my $.02
Old Jun 17, 2003 | 10:40 PM
Car: 91 RS
Engine: 350 TBI
I asked him, he said it is emissions legal.
Isn't there like some sort of Vortech kit I would need though to put this thing in and be emissions clean? I don't think my stock stuff would transplant over.
Old Jun 18, 2003 | 06:21 PM
Car: 91 RS
Engine: 350 TBI
Come on guys, I'm seriously thinking about purchasing this thing. Is there some sort of kit I'll need to make my current emissions crap work with the vortec stuff? How does it translate to everyday driving (mpg etc)?
Old Jun 19, 2003 | 12:04 AM
Jackal8069's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
Well, The air tubes from your exhaust manifolds are outside the actual long-block there, so thats ok, and I believe that the intake has all the stuff for EGR and what-not. And the heads have all the accessory bolts for running a smog-pump setup; though I don't recall where the smog pump straps on to. Check the cam too, I took a glancing look but didn't really think of analizing it. If I remember right, if you have enough over-lap you don't need to run an EGR. The guys at Chevy Hi Performance have a 350 under a computer-controlled quadra-jet that doesn't use an EGR.
So, yes, it'll be able to bolt up to all your smog equipment. Just take a good look at the cam too
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
