TBI code 43 help!
Old Jul 3, 2003 | 09:02 AM
Red_Demon's Avatar
From: Currently State College Pa, Usually, I live out side of philly.
TBI code 43 help!
ok so I just got finished installing new headers on the car and I took it for a drive. This error never occured until I installed the headers.
Well seeing that the new headers were going to give me a horsepower jump I decided to mash the gas just once to see what it did. I was terribly upset the car barely tried and felt worse than a 4 cylinder.
It was that time that the code 43 popped up (just as I was mashing the gas)
What do I do to fix this problem. And someone please simplisticly tell me because I have read about 20 different posts and don't understand what I'm supposed to do.
-Justin
Old Jul 3, 2003 | 10:28 AM
Crisis's Avatar
the code.
43. Low voltage at electronic spark timing circuit
This means you've got something gone to hel* with the ignition.. i suggest you check all the leads to the distributor and coil.. Then on the other hand if your gonna mod the car more you could just get an msd ignition system.. it would save you the time and trouble since youre gonna be upgrading the ignition anyway if youre gonna build the engine more.
Still if you're gonna look for the fault i suggest taking the battery cables off and with a multimeter checking all the spark advance control leads.. Make sure you havent burt and plug wires... if any of them seem burt just get an aftermarket set.. there usualy better and cost the same anyway..
Run winaldl.. if you can... that would help alot.
Old Jul 3, 2003 | 11:07 AM
JPrevost's Avatar
Car: 91 Red Sled
Mess around with your base timing. It's tuning until you do REAL tuning and disable the stupid code 43 with a patch.
Old Jul 3, 2003 | 11:49 AM
Red_Demon's Avatar
thanks for the info.
About patching the code 43 how do I pull that off?
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
Glowsock
Sep 11, 2015 11:09 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
