Vortec heads
Vortec heads
Hey I am new here, I have a 1992 Camaro rs with the 305 and tbi, I heard that vortec heads make a huge difference, has anyone done the swap? Is it just plug and play, or are there other things I need to change, like the intake manifold, or chip. The car is pretty much stock right now except for an MSD 6A box. Need more power....
Pete
Pete
Re: Vortec heads
Pete
Pete
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I'll try to help you out. I also have the same Camaro. I consider us to be lucky, because we can buy any cylinder heads made for a SBC 305 5.0L. We can do this because when the nice folks at GM changed our cylinder heads to center bolt Vortecs in 1987 they only changed the bolt angles from the intake to the heads a few degrees. So if you would like to buy older heads all you have to do is drill a different angle in the intake manifold to match the bolt angle on the older heads. Buying older heads will 1)allow you to save money. 2) find parts easier. 3) allow for a more custom engine look. I put pre 1987 World cylinder heads on mine and I love it. Made me 11mph faster in the 1/4 mile. I'll try to post a picture. I have no idea if this helped you.
Car: 1985 Camaro
Engine: 5.7, Vortec heads, Headers, TBI
Transmission: Built 700R4
Axle/Gears: 3.23 BW 9-Bolt Disc Brake
Your right about pre 87 heads being a different bolt patter than post 87, but vortecs are a completely different polt pattern. The pre87 heads have all bolts perpidicular to the head mounting flange, the post 87 heads have the two center bolts angled slightly up and you can grind an older intakes to fit. Vortecs on the other hand have 8 bolts instead of 12 and all bolts are vertical as in strait up so they go into the head at a steep angle, No way to grind an older intake for that, just have to get a vortec intake or you could get funky with it, i doubt you wanna do that, the cirlce track guys have.
Car: 89 Camaro RS
Engine: 305 TBI
I did the vortec swap. You'll need to mill the heads down .030 to keep the compression ration stock. Then you'll need a vortec specific intake. I would also recomend doing a cam at the same time. The LT1 cam is about the largest recomended for stock vortec springs. The whole swap will probably cost around 900 bucks when all said and done.
Car: 89 Camaro RS
Engine: 305 TBI
It's taken awhile, but my tune is pretty close. I've got it idling well and it pulls really hard at part throttle. With the vafpr that I just put on it got me alittle close but it's rich up top, so if I can ever get the adjustment screw to break loose I'll take a couple psi out of the fp. With more tuning low 14's are in sight, and maybe 13's with DR's. Sometimes I can't really get on it hard during warm up period, I think it runs alot richer till it's warm which causes a miss, but overall it acts like a stock controlled motor.
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
dont mill the heads if you plan on going to a 350..
doesnt a 350 with vortecs and lt4 cam make real good hp numbers? i wonder what it would do with maybe a 454 tbi on top... anyone try this? i am just dreaming up ideas.. i wanted to do the 350 idea with a carb but decided against it.. 305 is just a mild performer we need more 350 tbi's
Shawn
Shawn
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
89fastlookinrs, what psi is the vafpr pulling at wot/idle? I got the walbro in and the stock fpr is dead set at 15 psi maxed out, I'd like to be pulling ~19 wot.
Thanks man
Thanks man
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Shawn
Shawn
Attached photo shows how I routed the exhaust into the manifold from the headers to keep the EGR working.
S-D
edit: I also kept the stock throttle body, just put in bigger injectors.
Can you just bold on the heads, intake manifold, and new chip and it work ok? Or does everything else need to be tuned? Also, do you need special vortec headers like the intake manifuld?
Car: 1991 RS
can we have more engine bay pics of that please..
Shawn
Shawn
I took these pictures in a very large and fine format, so they must be shrunk down. Hopefully they'll attach correctly.
Is there anything in particular that you are looking for?
Car: 1991 RS
If you put the heads and intake on, I would also plan on headers to allow it to breath. Exhaust ports on vortecs are of the same design as standard Chevy heads far as I know. The SLP's I put on work fine. They were listed to be used on the stock motor for my car 91 Camaro RS.
I would plan on learning how to use the WinALDL program and also getting the equipment to burn your own chips if you do heads/cam intake and headers.
I learned from the ground up. I did a lot of reading (mostly all on this website) before I bought anything. With the proper background info and equipment the chip burning was a good experience. I would avoid buying the equipment and then trying to learn how to use it. It is too frustrating. Make sure you have a good working knowledge of the overall function of the equipment before buying.
There is a ton of excellent info on this site that tells a user virtually everything needed to get of to a good start.
Obviously, I can't say enough about the tech content of this site- it is very good.
S-D
Car: camaro
Engine: mighty 305
where did you get that air cleaner assembly? is that on a tbi?? nice to see some other alternative other then dual snorkel or open element... did you fabricate that yourself? i would be interested in one of them..
Shawn
Shawn
Car: 1991 RS
The part that sits on the Throttle body is plastic and came stock on the 93 caprice I got the motor out of. I cut off the front half of it and extened it with a sheet metal plenum so that the stock TPI intake and hose would mate up to it. It wound up taking alot of time, but it clears my hood and works very well.
S-D
S-D
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
