TOTW - 7-28-03 - Been gone for a while. Come back and tell us your new mods/results
Old Jul 28, 2003 | 10:16 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Topic of the week has been dead for a while. as you can see some have brought back the totw-pics of ultimate tbi..
im gona do my best to bring this idea back. send ideas for the next 3 months of totw to me at snflupigus@hotmail.com
well keep this thing going.
later
nic
Old Jul 28, 2003 | 10:34 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Mods:
Suspension - (right now since i broke a few peices)
Spohn Panhard
SwayBars
Poly Bushings (sway-bars, Trans-mount)
in the current setup, factory torque arm, and LCA's ( see above reason)
Engine -
stock but K&N, 160* t-stat, 5/8" TBI Spacer.
Exaust -
3" Catco Hi-Flow CAT
3" Flowmaster American Thunder
Driveline
Lightweight GMPP Flywheel
Centerforce DF clutch
Pro-5.0 Shifter
LS1 Alum. Driveshaft
Eaton Posi
3.42 Richmond gears
i went to the track like this, with full interior, and the works. on crapy 235/60/r15 BFG Radial TA tires.
results : 16.1@87mph , i was only able to get a 2.64 60' time (tires suck, and so did the track), also, i was having some problem with my custom chip, so that was done on the factory chip, with 0* of timing, i normaly run a chip with 4* built in, and some working over of spark and fuel tables. i know there is a 15.7-15.8 run in this car, if i could get some traction.
i also dyno'd this before the exasut mods, with a clogged CAT, i was only able to best 110rwhp (at 2200 rpm, thank you clogged cat) but did put down 255rwtq at that same point 2200rpm) after that it fell on its face.
BTW, snflupigus, i really like the TOTW, it helps keep the board from having the same 4 questions all the time
Old Jul 28, 2003 | 11:18 AM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
LT1 cam and z28 valve springs
Edelbrock TBI Performer manifold
3.42 richmond gears and SLP posi unit (big seat-of-pants difference)
MSD 6A ingnition box and Blaster Coil
Before summer is over:
3" high flow cat, and maybe a hooker cat-back
Im working on tuning my own chips, but i need an adapter for my ecm to use the 29C256 chips (can anyone help me here)
Ive got the aldl scanner thing i made all wired up in my car, and ive got a laptop and PPII
i think that's all I've done this summer... this was my first summer to have a real job
results: much faster, still not fast enough
no track times yet...
Old Jul 28, 2003 | 04:07 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Only mods so far are:
Non-drop base open element
Catback with Flowmaster 80 series
6* of timing advance
3.42 gears with the zexel torsen posi carrier
New Z-rated tires all around
The car really hooks up hard now off the line with the gears, posi, and tires. I should be going to the track very soon and I'm hoping for a low to mid 15 but we'll see.
As far as my engine swap, I've been swaying back and forth as to what to do with it but I think I have it down now and am starting to tear down the engine any day now.
Old Jul 28, 2003 | 04:12 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
So far this summer,
*I have built all new exhaust..(EGR no longer works from lack of backpressure).
*Added home-made sub frame connectors
*Made some custom door panels
*Developed some ping since the exhaust that I can't seem to get rid of.
*Just ordered all the fixin's for the new motor.
Old Jul 28, 2003 | 05:44 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Mods are all in the sig, working on tuning the chips. I think I almost have her tuned right. She's going to make it to the track sooner or later. If I have a set of slicks when I get her there I'm shooting for 13s. Without slicks hopefully around a 14 flat. Time will tell sooner or later.
Old Jul 28, 2003 | 05:53 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
MODS:
HyperCRAP cap and rotor / MSD wires / Rapidfire plugs at .045 gap / MSD coil / Advanced timing 8*
3.23 gears / SLP posi / Trans-go shift kit / Vette Servo / tranny cooler
KYB struts and shocks / Global West steering brace / Spohn SFC's, LCA's with relocation brackets, and panhard bar
Jet Fan switch / 180* t-stat / Stewart Stage 1 WP
K&N open element w/ Xtreme Top
Dynomax cat-back
Today I just installed all the Spohn stuff. The car definately feels tighter, but I only drove home from the shop, so it's only been about 2 miles to compare it on.
The biggest difference is a tie between advancing the timing and the gears w/ posi. It's like even on the interstate, I'm still in my power band. I highly recommend the 3.23's if you drive on the interstate alot.
The advanced timing really gave a SOTP difference, but it sucks having to buy high octane fuel, and even with that, I still have a little knocking at low RPM's.
Assuming my car was still putting out the stock ratings when I started, I picked up 10 HP and 8 lb/ft with the K&N and advanced timing.
Also, if you're looking for a nice quiet, but deep exhaust note, I highly recommend the Dynomax setup. No annoying drone what-so-ever.
I have no track times yet, but maybe when I get back from overseas, I'll knock some out.
Old Jul 28, 2003 | 08:21 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
1989 Pontiac Firebird Formula Black 305 tbi 116K miles
1.Flowmaster muffler 80 series
2.Lakewood rear control arms
3.Hayden tranny fluid cooler with 10" fan
4.Energy suspension fron sway bar links.
thats all ive got for now my tranny blew after road course racing through the neibhor hood.
So know im either going to go with the t56 or $1,400 auto transmission.Or buy a used one for $200 to show off in front off a friend and score.
Old Jul 28, 2003 | 09:26 PM
novadk13's Avatar
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
edelbrock tpi headers
3 inch dynomax high flow cat
flowmaster 3inch catback 80 series
getting the stage 2 chip and stat in this weekend
gonna order world torquer heads and edelbroke intake soon
gettin a laptop and gonna get stuff for burning chips comin up
thats it for now
Old Jul 28, 2003 | 09:36 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
LOL i believe i have done most of this since Tas was around
Engine:
4 Bolt Main 350 bored .030 over (355)
Stock crankshaft
Side polished and shot-peened rods w/ ARP fasteners
Keith Black Flat Top Pistons
XE 274 Camshaft
Stock 1.5 rockers with screwed-in studs and guideplates
Ported and polished bowl blended smogger heads
2.02" Intake Valves, 1.60" Exhaust Valves
Weiand X-Celerator Single Plane Intake
1" Open Carb Spacer
Edelbrock 750 CFM electric choke carb
Flat Bottom 14"x3" K&N Air Filter
Transmission:
"Corvette" Stall
Ignition:
Accel Replacement HEI Distributor
Accel 45,000 HEI Volt Super Coil
Taylor 8mm Spark Plug Wires
AC Delco Spark Plugs
Rear End:
Stock 7.5” 10-bolt rear-end
Richmond 3.73s
SLP take-off posi
All seals and bearings were replaced when the gear/posi swap was done.
Suspension:
Boxed-stock LCAs
Polyurethane front and rear sway bar endlinks
Polyurethane front and rear sway bar chassis mounts
Polyurethane transmission mount
Summit Racing 3-way Adjustable Rear Drag Shocks
Air Lift Air Bags in the rear springs
Cooling:
17" Heavy Duty Derale Flex Fan with a 2" spacer
B&M 24,000 GVW transmission cooler
Stewart Stage 1 Water Pump
160º Thermostat with two ¼" Holes
Exhaust:
Hedman shorty headers, with their y-pipe that I ported and modified(single pipe is now all 3")
Straight-pipe catalytic converter
3" pipe all the way
Flowmaster 40 Series Race Muffler w/ Turndown.
Weight:
3,340 pounds full race weight.
Appearence/Misc.:
1991-1992 Z28 Rims, IROC fog lights, Harwood 4" Cowl Hood, Z28 Grille, Custom LED 3rd Brake Light, Sylvania Cool Blue Low and High Beam Headlights, Proform Shift Light, Triple Gauge Console, R&M Billet Spark Plug Wire Looms, Moroso Chrome Valve Covers, Keyless Entry, 235/55/16 Firestone front tires (came with the car), and 295/50/16 BFG T/A rear tires
Stereo:
Pioneer CD Player, Pioneer 4x6s, Pioneer 6x9s, Profile California Series Amp Powering 2 10" Pioneer I.M.P.P. Subs.
Old Jul 28, 2003 | 10:42 PM
Car: 91 RS
Engine: 350 TBI
Brody: With all that crap, how fast are you going?? That's a lot of time and money you put into that car.
Old Jul 28, 2003 | 10:50 PM
you're telling me.
i dont know how fast im going but i am going to the 1/4 mile track for the first time friday (8/1/2003). however i know i would be going WAY faster if it wasnt for these two things:
"Stock 1.5 rockers with screwed-in studs and guideplates
Ported and polished bowl blended smogger heads"
and
my current torque converter
those two things (mainly the heads) are really hurting me
Old Jul 29, 2003 | 06:23 PM
BronYrAur's Avatar
Engine: 305 TBI
Hey brody, I've been thinking about boxing my stock LCA's as well, did you notice much of an improvement when you did them? Does it really stiffen it up good or should I just wait and shell out the dough for some spohn tubular arms or something of the like?
Old Jul 29, 2003 | 07:26 PM
Car: 91 RS
Engine: 350 TBI
I went with the Spohns. They definately tighten up the rear, maybe too much. I no longer bark the tires going to 2nd or 3rd. It just hooks and goes. A little noisy for my taste, but definately hooks better.
Old Jul 29, 2003 | 10:46 PM
vjo90RS8's Avatar
Car: 2002 Z28
hopefully by the end of summer ill have a Pro Built Street/Strip tranny, ACT 9.5" 2400 stall TC, and 1.6 rocker arms.
rest of mods are in sig.
Old Jul 30, 2003 | 06:15 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Everything in the sig plus SLP Headers, Cutout, Harwood 4" Outlaw Z Hood with a cold air box (air box isn't done yet), Subframe connectors (coming soon), and gettin' some prom burning equipment pretty soon too.
I'm hoping for mid 14's off the bottle and high 12's on a 100-150 shot or so (whatever it takes I'm crazy enough to do it )
Good Luck to all
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
justin57
Aug 20, 2015 07:05 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
