Very Stupid Problem
Old Aug 9, 2003 | 06:39 PM
prophecy xi's Avatar
Very Stupid Problem
Hello i`m new. love the site. ok here goes very wierd pronlem, i just put long tube headman headers on my 89 firebird and today i just put my new taylor 8mm spark plug wires on it. heres the odd part when i went to start it. it fires up idles great i try to rev it a bit to hear them open headers and the rpms goto 2,000 on the tach but it wont go back down! so i figures it was a vacum hose on my air cleaner. i reatached the air cleaner and all the hoses and it still does it. anybody know?
Old Aug 9, 2003 | 07:20 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
One question right off the bat. IIRC, and I could be wrong, the full length hedmans do not have a oxygen sensor bung on them. Did you have one installed, so that you could run your O2 sensor?
Old Aug 9, 2003 | 07:29 PM
no i gotta get one but i`m waitin on a tuned port to come that i ordered off ebay
Old Aug 9, 2003 | 07:47 PM
I don't know for sure what the effects will be of running without an O2 sensor, but both TBI and TPI need one on there to run properly.
Old Aug 9, 2003 | 07:49 PM
SlowMaro's Avatar
do you mean the tach doesnt drop? or the engine just stays at 2 k
Old Aug 9, 2003 | 07:50 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
see how it works when you get the o2 hooked up properly. The ecm wont like not having that sensor. Probably also a good idea to consider getting a heated O2 for your LTs. Not absolutly necessary but it would help fuel economy and emmisions.
Old Aug 9, 2003 | 08:33 PM
25THRSS's Avatar
The 02 wouldnt have anything to do with the car not revving over 2,000. All it will do is cause him to stay in open loop and waste fuel, but he should still be able to rev past 2,000.
Old Aug 9, 2003 | 08:54 PM
SlowMaro's Avatar
just a thought, maybe the linkage is messed up , or hitting the air cleaner? i thought he ment it reved to 2 k and never dropped back from 2 k
Old Aug 9, 2003 | 09:00 PM
25THRSS's Avatar
yeap, I read it wrong Sounds like a vaccum leak to me or could be the linkage like you said.
Old Aug 9, 2003 | 09:51 PM
SlowMaro's Avatar
i have no clue what vaccum leak would make a car not rev back down. im thinking its a kink in the throttle linkage or somewhere within the springon the tbi linkage, theres a problem, that or your idle screw got turned, ALOT, or yout timing is seriously jacked up.
Old Aug 9, 2003 | 10:32 PM
i have the o2 sensor plug in it just hang off the sway bar.
Old Aug 9, 2003 | 10:34 PM
The eninge stays at what ever rpms i put it to.
Old Aug 9, 2003 | 10:35 PM
25THRSS's Avatar
Definitely a kinked throttle cable! DO NOT DRIVE IT LIKE THAT!
Old Aug 9, 2003 | 10:38 PM
lol no way i`m puttin it in drive lol,i`m kinda thinkin somehow the cruise control is stuck on or something stupid like that. its drivin me nuts though, i`m gonna tear the cruise control off tomarrow morning.
Old Aug 9, 2003 | 10:40 PM
25THRSS's Avatar
The cruise control works off of mph, not rpm. Check and make sure you dont have the throttle cable caught on anything or bent at all.
Old Aug 9, 2003 | 10:42 PM
will do. hopin to get the bird doin 13`s by next summer gonna load up a tpi full of slp goodies.
Old Aug 9, 2003 | 11:21 PM
Krag's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 w/TPI
Transmission: 6-speed
Sounds like the return spring is not doing the job! Does your TBI have a return spring like a carb? I it does it sounds like it came unhooked.
Old Aug 9, 2003 | 11:37 PM
SlowMaro's Avatar
nah the throttle return spring is made into the linkage, ..but that very well may have broken.
like i said before, its prolly the throttle cable kinked. or your linkage spring broke. spray it down with some carb cleaner.
stupid question but, did you forget to put the lil metal retainer clips on the throttle cable AND the cruise control cable?
i did that once, and hit the road, car stuck at wide open throttle, in the rain, with a car going super slow infront of me. that sucked. i managed to not hit them or tear up my car though....thank *** for neutral and a key lol....
maybe your TPS is binding, and not letting your throttle drop.
and yes, your cruise control will only engage at 40 mph. i know, i use mine enough. check the entire linkage assembly though. i suspect the problem lies there.
Old Aug 10, 2003 | 01:49 AM
You still need to fix that ASAP.
Old Aug 10, 2003 | 02:45 AM
SlowMaro's Avatar
i second that, unless you plan on throwing the tbi and ecm away, if thats the case, drag that dirty bastard down the road like that til sparks fly, ...o2 sensors **** me off, ....make it take one for the team! heh
Old Aug 10, 2003 | 12:14 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Dear lord tell me you're kidding. This will tell the car that you're super lean and will dump your whole gas tank into the little 305...
Old Aug 11, 2003 | 03:44 PM
i`ve checked all that u guys mentioned today, i pushed the throttle with the engine off and it returns.i have no ideas left lol about to say screw the tbi and throw the tpi on when it comes in.
Old Aug 11, 2003 | 04:07 PM
SlowMaro's Avatar
man if you think you have problems now, wait til you do the tpi swap. sure itll work, but i heard it was a bitch to do. i wouldnt know for sure though seeing how ive never done it. maybe your pedal is getting caught on the carpet?? lol i dunno.....check the idle air control as well.
Old Aug 11, 2003 | 05:03 PM
Car: 88 Camaro SC
Engine: SFI'd 350
check teh throttle with the engine running. The forces from the vacuum on the butterflies will sometimes cause binding that doesnt happen with the engine off.
Old Aug 11, 2003 | 08:17 PM
lol theres no carpet. i`m doin a resto kinda tempted to leave out the interior. but actually in my tbi`s butterflies even with the motor off there has always been a weird bindint sound coming from it like a chirp.
Old Aug 11, 2003 | 11:41 PM
Car: 88 Camaro SC
Engine: SFI'd 350
sounds like the tbi casting is badly worn around the throttleshaft if it makes squeaking noises. Tahts probably the butterflies hanging on the walls of the barrels. To be sure, firmly grasp the throttle shaft and move it around with the throttle open partway. If there is play, then its time to replace the tbi or have it rebushed.
Old Aug 12, 2003 | 08:20 PM
u maybe right it has 160k orginal miles with a semi fresh rebuild on it. the guy i got it from had it rebuilt probably thing were wearin out on him.he replaced alot of things.
Old Aug 12, 2003 | 10:57 PM
Krag's Avatar
Engine: 406 w/TPI
I went from a carb to TPI in my 1988 Monte Carlo SS and it wasn't too hard of a swap, I used an external fuel pump and ran a 5/16" steel (I used brake line) line for a return. The wiring harness comes out pretty easy and the new computer hook-up was a snap.
I had to have a custom chip burned tho 'cuz I am using Speed Density, a T-56 6-speed, 406 c.i.d., the TPI builds incredible torque!
Tony is right about that 02 sensor, you MUST have that hooked up and functioning properly!!!! The computer will indeed see the A/F ratio as SUPER LEAN and 'try' to get it right by telling the injectors to richen it up!
Old Aug 12, 2003 | 11:07 PM
Car: 88 Camaro SC
Engine: SFI'd 350
lol, my friend has almost the same exact setup in his monte except he has a vette L98 350 and not a 406.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
