Does this mean I need chips?
Old Aug 24, 2003 | 02:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've installed LT1 cam, ported/polished #416 heads, 1.94 intake valve, 1.5 exhaust valve, 1.6:1 roller-tip rockers, Weiand #8000 carb intake, Hedman Headers, Gutless Cat.
Engine surges all the time, at any speed and at idle, and it wants to die at stop sign.
I can't find any vacuum leaks. I increased fuel pressure at regulator, no effect. I set timing all over the place, no effect. Fuel pump seems to be fine. Haven't tested fuel pressure yet - awaiting guage to ship. New MAP sensor, no effect.
Nothing I do seems to make any effect, good or bad!
Does this mean I need chip tuning?
Old Aug 24, 2003 | 02:48 PM
wuz_up92085's Avatar
Car: 91 RS
yes, with any mods you should get chipped customed burned, your computer still thinks everything is the same and is trying to fix it sort of
Old Aug 24, 2003 | 04:42 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
yes i am sure you need a chip.
just out of curisity how far did you set the timing up? i would guess with that setup your engine is going to want alot of timing at idle. and you are porbbaly going to be running VERY lean up top. sort of a catch 22, you ad more fuel everywhere , it idles like crap, you add timing everywhere, it runs like crap up high.
thats why your going ot need a chip.
Old Aug 24, 2003 | 04:57 PM
Car: 1992 RS
Engine: Carbed 350
my timing is set at highest vacuum from the manifold - it's off the scale in the high range, like 16 or something - i'm wondering if my mark (outer ring on balancer) slipped - highest vacuum was only way i could have something to set it by
Old Aug 24, 2003 | 05:02 PM
Dewey316's Avatar
Car: 1990 Camaro RS
with it timed to high vacume, you should hae noticed a better idle, but it would have run bad everywhere else, because you would have had way too much timing up top.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
