Biggest Cam For 89 Stock Camaro
Old Aug 28, 2003 | 12:33 PM
ckeene502's Avatar
i was wodering what would be the biggest cam i could install in my wifes 89 305 tbi camaro. i have a cam from tpis left over from an old project and would like to put it in her car. i think its---.480 intake and .520 exhaust and thats gross lift. thanks
keene
Old Aug 28, 2003 | 12:38 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i wouldnt suggest putting that cam in a stock LO3. there are many many reasons why, but i gotta go to class....
Old Aug 28, 2003 | 12:46 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
that is way too big for stock heads, the lift is way too much you would put the springs in bind, and that lift would pull the studs. the duration is also way to much for the stock computer.
Old Aug 28, 2003 | 01:02 PM
ckeene502's Avatar
What would be the biggest allowed in the L03?:lala:
Old Aug 28, 2003 | 04:45 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i dont know if there really is a clear cut line. obviously something like a solid roller with 240 some odd degrees of duration and .6 in of gross lift is a definate no-no. Id say use an lt1 or possibly a vortec cam. either of those would be a reasonable match to what you have. Id also like to say the ramjet cam but the lsa is a bit tight for the stock tuning, although it would be a great match for the stock engine.
Old Aug 28, 2003 | 04:46 PM
Car: 88 Camaro SC
Engine: SFI'd 350
id also stay below .460 in. of lift with the stock heads.
Old Aug 28, 2003 | 05:31 PM
Dewey316's Avatar
Car: 1990 Camaro RS
yes, and the computer will not like anything on an LSA smaller than 112, but 114 is probably easier for the stock computer.
Terrell351
Jun 13, 2021 01:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
