Roller Rockers?
Old Sep 14, 2003 | 04:32 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Roller Rockers?
I was thinking about doing a quick engine mod to gain a little power. Has anyone ever done a rocker arm swap? I was thinking about going with 1.6 rr. The L03 has 1.5, right? And would I have to change the valve springs, and if so, which ones should I go with and the cost, ect. ect.???? Just trying to think of weekend power adders that dont' break my bank....any help would be nice
Thanks!
Lc
Old Sep 14, 2003 | 05:04 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Going to 1.6RR would give ya a little more lift. You wouldn't have to change springs. Power increase probably wouldn't be huge though.
vjo90RS8's Avatar
Car: 2002 Z28
I just installed some stamped steel 1.6 rocker arms and i noticed that it does pull alittle harder now, im going to the track on wednesday, well see how much they helped then.
Youll be able to use the stock valve spring because even with 1.6s, the lift is still small (.373/.409).
Old Sep 14, 2003 | 06:29 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
a lt1 cam will be great with 1.6 rockers but then u need vale springs to good for like 60 hp i think good mod
Old Sep 14, 2003 | 08:28 PM
305RSlc's Avatar
Excellent...that makes this whole thing a whole lot easier....so it seems. Still gotta get by all that air conditioning and smog crap just to get the passenger side valve cover off though...
As far as cam swapping goes....how long does it take and is it actually worth it to pull the engine??? Thanks all!
Lc
Old Sep 14, 2003 | 08:53 PM
305RSlc's Avatar
Also, should I go with the roller rockers or stamped rockers? Do either offer any pros or cons, any one easier to install????
Lc
Old Sep 14, 2003 | 09:10 PM
Go full rollers.
Old Sep 14, 2003 | 09:39 PM
305RSlc's Avatar
Ugh, sorry about all the questions but I keep thinking of something as I walk away.
Should I get self-aligning or does it matter with the L03 heads?
Lc
Old Sep 14, 2003 | 11:06 PM
SA
Old Sep 14, 2003 | 11:42 PM
vjo90RS8's Avatar
Car: 2002 Z28
self realigning is a must, i went with stamped steel Federal Mogul rocker arms because they were only $68, i couldnt see spending almost 300 on full rollers for a L03. You can also look at Comp Cams Magnum roller tip rockers, run 192 through summit.
Old Sep 15, 2003 | 09:36 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
also you don't pull the engine to do a cam swap!
also i already have the lt1 cam and i would like to go to 1.6 rr's i am going to get the screw in studs and also what is a good spring to get that i don't have to modify the seat? i want some that will swap right in.
Old Sep 15, 2003 | 10:01 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the best you are probably going to get in a 1.25" spring si the HD z/28 springs through scoggin dickey.
Old Sep 15, 2003 | 10:12 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
WOULD THEY WORK WITH THE LT1 CAM THOUGH?
Old Sep 15, 2003 | 10:28 AM
Dewey316's Avatar
Car: 1990 Camaro RS
easily they claim to be good to .550 lift, though i would not trust them at that lift for too long.
Old Sep 15, 2003 | 11:25 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
Well my lt1 cam is out of a 95 firechicken... how do i do the math to see if that would work
Old Sep 15, 2003 | 11:26 AM
Dewey316's Avatar
Car: 1990 Camaro RS
it will work, none of the LT1 cams are anywhere near .550 lift, in fact none of them are even close to .500 lift.
Old Sep 15, 2003 | 11:43 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
i think it was around 475 or so but with the 1.6 rockers doesn't that change the numbers.
Old Sep 15, 2003 | 11:46 AM
Dewey316's Avatar
Car: 1990 Camaro RS
no, the LT1 specs are with 1.6 rocekrs, because the lt1 had 1.6 stock.
Old Sep 15, 2003 | 12:17 PM
No, the LT1 had 1.5 stock. Therefore those .450/.460 lift numbers you see are using 1.5 rockers. You are getting mixed up; the LT4 came stock with 1.6 rockers.
Keep in mind that actual lift on the LT1 and LT4 cams are very similar.
Old Sep 15, 2003 | 12:19 PM
Dewey316's Avatar
Car: 1990 Camaro RS
blah, its to freakin' early.
Old Sep 15, 2003 | 12:30 PM
Just got outta class. I'm feeling smart lol
Old Sep 15, 2003 | 12:32 PM
Dewey316's Avatar
Car: 1990 Camaro RS
well, i didn't stay at a holiday inn express last night maybe that is my problem
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
what are you talking about... i know those are the numbers with 1.5's but i am asking if i use the 1.6's if that will make those springs useless...
Old Sep 15, 2003 | 12:33 PM
Dewey316's Avatar
Car: 1990 Camaro RS
do that math dude.
( lift / 1.5 ) * 1.6
THEY WILL WORK.
Old Sep 15, 2003 | 12:36 PM
Yup, that's what rockers do. Increase the life and move it to the valve. 1.5 rockers multiply the lift they receive by 1.5, 1.6 does 1.6 times the lift...
Old Sep 15, 2003 | 01:20 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
The average LT1 cam (I say that because they changed lifts a few times but nothing drastic) will be about .475/.490 with 1.6's. Nothing at all to worry about with a decent set of springs.
Old Sep 15, 2003 | 01:53 PM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
cool thanks...
Old Sep 15, 2003 | 04:38 PM
305RSlc's Avatar
cam???
So how do you get the cam in without yanking the engine??? What do you pull off the front end or something....looks kinda small an area to be installing a cam, but I have never done it so please do enlighten me.
Lc
Old Sep 15, 2003 | 04:46 PM
305RSlc's Avatar
You aren't talking about the LT4 Hot Cam, are you??? Because with 1.5rr's it has .525/.525 lift....that doesn't seem close to the LT1's .450/.460. Just making sure.
Lc
Old Sep 15, 2003 | 07:40 PM
Lc
Search, both this site and the internet. Also might want to get a book.
Lc
No, I said the LT4 cam... But you are incorrect on another figure. The LT4 HOT CAM has .525" of lift with 1.6 ratio rockers. It has .492" lift with 1.5 ratio rockers.
Old Sep 15, 2003 | 08:03 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Re: cam???
no you remove the radiator, and move the AC evap, and you can just sneak a cam in there
Old Sep 15, 2003 | 08:04 PM
305RSlc's Avatar
Ooops, my bad, you're right. I was going by Pace Performance catalog and they advertise the LT4 hot cam as .525/.525 with 1.5rr at the top of the page. Just went to check it, and at the very bottom is says rated with 1.6rr. stupid subscript
Lc
Old Sep 16, 2003 | 10:02 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
yes you remove the rad and i moved the evap...
Old Sep 16, 2003 | 01:12 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
If you're using an LT1 cam with 1.6's being close to .500" of lift with stock LO3 heads aren't you just wasting the extra lift the 1.6's gave you because the heads can't flow enough for that kind of lift anyway? I always thought an LT1 with 1.5's was close to the most lift that the LO3 heads would take and still flow OK.
Old Sep 16, 2003 | 03:53 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
the a/c evap is the radiatior lloking thing on front of the water radiator right?were do u move it to the front do u have to disconnect the lines that run to it or is there enough space to move it ?
Old Sep 16, 2003 | 05:53 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
You can pivot it, or hang it up or whatever you want to do with it. You'll have to drop your oil pan in the front so you dont mess up your oil pan gasket. Obviously the distri and intake will have to come off, so you minus well get a decent new manifold - carb style or the Edelbrock tbi. Id take the front accessories off if it were me, but everyone is different I guess. If you do you dont have to disconnect the a/c.
The engine if out of my car in this pic but you get the point:
Old Sep 16, 2003 | 08:33 PM
305RSlc's Avatar
So it's feasable to just put 1.6rr on the original L03, or just put int the LT1 cam, but not both? Shucks, that saves me money on a possible weekend power adder......hehe yay. 60hp for around $150 and about a weekend worth of work...sounds good to me! Thanks all!
Lc
Old Sep 16, 2003 | 09:02 PM
BronYrAur's Avatar
Engine: 305 TBI
Actually, I'm really surprised someone didn't dispute that post by that guy above about 60hp. That isn't going to happen. If it were me I'd go with just the LT1 cam and some new springs and keep my stock rockers on there. Also, about getting a new intake manifold that's a very good idea too as well as a new timing chain. The stock LO3 cam isn't good even with 1.6 rockers, go with the LT1 and wait to get 1.6's or a bigger cam until you have aftermarket heads or upgrade to a 350. Just an LT1 cam and an aftermarket manifold on an otherwise stock LO3 will give you nowhere near 60hp maybe 30? it differs engine to engine.
Old Sep 17, 2003 | 07:51 AM
rsscoty's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: auto
How much do you have to shorten the dowel pin on the front of the LT1 cam before installed. I have the cam and heads waiting to be done.
Scoty
Old Sep 17, 2003 | 02:56 PM
txhotRS's Avatar
you only have to shorten it so that there is about 1/4 left on the cam... good luck with that... I had my cam for 2 years... but I didn't put it in until I yanked the engine and did a rebuild also... if you are going to spend the money on rocker arms.... JUST GET ROLLER's... if you have 2 engines with the same lift and duration and same rockers... and one is roller lifter/rocker, and the other is flat... the one with roller with have an almost 25% HP increase over the one with out... (given that everything else is the same)... it makes more difference than many people realize
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
