would this be hard?
Old Sep 17, 2003 | 10:45 PM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
would this be hard?
has anyone installed headers on there own car? if so how long did it take. and was there anything you had to do to get them in there. any pointers would help. thanks
Old Sep 17, 2003 | 10:48 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I put my hemans on my car, it took a couple of hours, i had to unbolt the motor and raise the engine a little to get the drivers side in. Other then that it wasnt to bad.
Kevin
Old Sep 17, 2003 | 10:50 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
first time i did it, it took all weekend..
after that, it was a 45 min deal... and when im in a rush i can do it in about 20mins..
what headers are you thinking about installing? ive only done headman shorties on my car...
Old Sep 17, 2003 | 10:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would say that 5 out of 6 people here instal their own headers. It isn't really hard. You just need time, some tools, and a lot of patience. You will swear, you will sweat, and you will think that you have totaly screwed your car, but you will get it done. Many novices here have done it successfully. Some people have done it in three hours, and others have taken days. It took me about 3 days working about 4 hours per day. I went very slow and learned a whole lot along the way. it is a rewarding feeling. The only hard part is trying to get you y pipe to fit to your cat and or cat back. You may have to drive with open headers to an exhaust shop to get it connected with thte rest of your system. I did and it was loud. Would I do it again....you bet I would.
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Putting the headers in my car was like the least fun thing I have done on my car yet. Putting them in was easy , but taking the old manifolds out on the passenger side was a pain in the a$$. The drivers side took me about 1 hr give or take a min to take the old manifold off and put the header in, I had to take the valve cover off to move the header into position.The passenger side was hard because of the back bolts on the exhaust manifold, on mine the very back bolt was touching the box that has the heater core in it. So I had to take that out. I also had to take my dip stick out to put the header in on that side. The Y pipe took like 10 mins. All in all it took me about 5 hrs, and I was taking my time so I wouldnt get mad at anything. Good luck.
Old Sep 17, 2003 | 10:52 PM
Car: 1992 Firebird
i was thinking about the slphttp://www.slponline.com/view_product.asp?PARTNUMBER=30000
Old Sep 17, 2003 | 10:54 PM
Car: 1992 Firebird
will the slp headers with the y pipe bolt right up to the stock cat?
Old Sep 17, 2003 | 11:16 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Installing headers wasnt too bad at all. I say for me about 6 hours or less....
Old Sep 18, 2003 | 10:12 PM
Car: 1992 Firebird
Old Sep 18, 2003 | 10:57 PM
25THRSS's Avatar
If you get the 2 1/4 cat adapter, but that would defeat the purpose of the headers in the first place.
Old Sep 24, 2003 | 10:27 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I got the 1 5/8 SLP headers awhile back form this board during a group purchase deal. It took me 2 days and believe it or not the driver side was harder to install. No I did not raise the motor to install the headers but maybe next time I do a header install on a chevy 3rd gen. I have have an after market cat so the SLP Y pipe did not bolt exactly to the cat. Notice a difference with the new header along with my borla exhaust and open air element. Good advice, make sure you have your spark plugs on prior to bolting the headers. Stupid me installed new spark plugs after I installed the headers. **For those individuals who purchased the SLP headers during the group purchase a long time ago, did you receive a CARB letter with your order? I never received one and I am up for a smog check.
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
