No gas while cranking
Car: 91 Camaro RS
Engine: 305 Modded
Transmission: 700R4 B&M blue clutches
91 rs 305 tbi ... isnt spraying gas while trying to crank. prime it and start it ..runs fine ..fuel pump relay is fine all fuses are fine ...any suggestions
Car: check
Engine: check
Transmission: check
Re: No gas while cranking
RBob.
Car: 1992 RS
SAME PROBLEM
The dist. module was bad on mine, even tested good at local advance. I would try it, it is about 30$ and 30 minutes to replace. I was ready to drop my tank!
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I had the same problem for years. I would check out the ignition module. I ended up going carb in the long run though
