How would car act if ...
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
The ecm would throw a code which in turn would hurt performance. tbichips.com has chips with egr turned off within the chip if needed.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
im not positive how yours would behave, but when my EGR broke, it made the car run extra rich when crusing and hurt my gas miliage.
Originally posted by Pablo
omg is that what I think it is.....
that? what that??
anyway... my egr was removed, block off plate etc, performer intake, car pings like crazy anywhere past half throttle and it feels like something is holding it back so i had to retard timing to where it is now, doesnt ping but the performance is severely lacking..
I get a code for egr once in a while but i thought that was removed from me eeprom
Engine: LO3;383tpi
That's because egr actually allows for a little extra timing. And because your chip still has the same timing chart, it is causing ping, which in turn is retarding your timing via ecm.
Engine: LO3;383tpi
Your knock sensor may be bad. Hearing pings or knocks is definetely not a good thing.
The ecm should be retarding the timing quite a bit, I not sure what the setting is in the stock chip, but I think it is something like 20*, but like I said not completely sure on that number
Ghettobird52
Jul 5, 2024 11:18 PM
