Got head info need cam stuff
Old Sep 23, 2003 | 01:53 AM
killertransam89's Avatar
I have an 89 trans am with the lo3 engine. My mods begin with all stock tbi free mods, turbocity spacer, performer intake manifold, power pulleys, headers, y pipe, three inch exhaust, and 3.73's in an automatic. There is alot of talk about the lt1 cam but I would like to stay with the edelbrock brand and would prefer that it is daily driven and not to extreme (if i could no computer tuning). What would be a good cam for about thirty to fourty horses (specs). Thanks fellas for the help.
Old Sep 23, 2003 | 02:19 AM
vjo90RS8's Avatar
Car: 2002 Z28
with the gains you are looking for you would have to go at least with the LT1 cam which isnt even all that aggressive, .447/.459 203/207. Also, edelbrock does not make a mild hydralic roller. If you want to go alittle milder than the LT1, use an L98 cam with 1.5 or 1.6 rocker arms.
Old Sep 23, 2003 | 01:25 PM
So the cam is a direct replacement or what else would have to be done. Thanks.
Old Sep 23, 2003 | 01:30 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
its pretty much a direct replacement, you have to trim the dowel pin, but that is it.
the comp cams (summit # CCA-08-500-8) is a nice cam also, it wouldn't be too bad, a little larger than the LT1, but with some computer work should complement that setup very well.
Old Sep 23, 2003 | 05:47 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Correcto, going to have to go aftermarket, or a GM piece.
Jake_92RS
Jan 28, 2020 10:37 PM
junkcltr
Aug 2, 2019 11:12 PM
gta90
Sep 15, 2015 04:00 PM
anesthes
Aug 8, 2015 09:37 PM
