Got a msd blaster coil, what spark gap?
I did a search and didnt really get an answer. I got a basically stock lo3 and I bought a msd blaster coil. Will it be beneficial to widen the spark plug gap to .45 and if I do what are the cons to doing this. Thanks in advance.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you might widen it out a little, even on my stock coil, i actulay ran a .40 gap all the time with no issues, with a coil like the blaster, you should be fine a .45
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I run the blaster coil and gap my plugs to .45. Just make sure you stay away from cheap wires if you do this for extra insurance.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What is the benifit of running .045 gap. I know since there is more spark it can make up the differnece in space but is there any performance/fuel efficiency gain with the MSD coil. I just changed my plugs recenlty and they are set to .035 exactly. Should I re-gap or would I be wasting my time. I have been running the coil for about three years now and have already fouled out a set of bosche plus platinum 4's.
Engine: LO3;383tpi
I'm not sure about the science behind it, but generally speaking, a wider gap equals more power unless you obviously gap too far. I can don't remember a sotp pants gain or anything when i went from .035 to .045, but maybe it was worth a couple of hp, and like they say every little bit adds up. I don't think it help my economy at all. Also, I would just wait until next time you change the plugs rather than regap now. That's just my opinion though, as changing those plugs can be pretty frustrating
Car: '90 RS
Engine: 377 LSX
Engine: LO3;383tpi
Like I said, the coil helped me out. However, I was already running the MSD-6A and 8.8 wires.
Low C1500,
Are you using the module? I have been interested in replacing mine with a high performance one, but wasn't sure if it would be worth it or not.
Low C1500,
Car: '90 RS
Engine: 377 LSX
After I installed the blaster coil I noticed smoother idle, better throttle resaponse and overall better mileage. I was pretty happy with it, still am.
Car: '90 RS
Engine: 377 LSX
Just make sure that you don't get shocked by it. For some reason whenever I change the timing on the car I get shocked, and boy does that hurt. Nothing like 40,000 volts to waken you up. I am only touching the cap to. It is arcing off of something and going right into me.
codeysabatini
Nov 10, 2015 04:07 PM
