by how much will my ets drop
Old Oct 14, 2003 | 07:00 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
i got shop to put on the gears for 200 dollars but they are putting all parts new high performance so by how much will my ets drop with 3.42 gears and a set of under drive pulley like .4?
Old Oct 14, 2003 | 07:23 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
it depends, when i went from 3.08 to 3.42 my ET did not change at all. although my MPH went up by 2, so i could have just been a bad night at the track for me.
Old Oct 14, 2003 | 09:06 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Some poeple have seen as high as .5 sec drop but that is with a 3.73 from 2.73 swap. Depends on what motor you have and what size gears you just replaced. You could easily see.4 with the right track conditions.
Old Oct 16, 2003 | 06:31 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
well i prder some parts from spohn suspension will this help me drop my ets?
lca's, panhard bar and streeing brace?and plus the 3.42 gears i will put in the year off the year
Old Oct 16, 2003 | 06:42 AM
Dewey316's Avatar
Car: 1990 Camaro RS
the LCAs will, a torque arm will really help also. the panhard, and steering brace won't really effect ET. they are more of a cornering peice. also LCA brackets will really help the car bite. make sure you have sticky tires too.
Old Oct 16, 2003 | 01:24 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
how hard is it to put on the brackets?i know u gotta weld them what do u do with the ones on the rear end now?
Old Oct 16, 2003 | 01:37 PM
Dewey316's Avatar
Car: 1990 Camaro RS
they fit over the ones in the rear, you don't remove anything. they are pretty easy, you should be able to take them to an exaust shop and have them weld them in for cheap.
NOTE: DO NOT INSTALL THEM THEN TRY TO DRIVE TO THE SHOP
Old Oct 16, 2003 | 03:19 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
You may wanna think about a higher stall as well, it will compliment your gears and headers
Old Oct 16, 2003 | 03:42 PM
deadtrend1's Avatar
You will see a bigger improvement of your MPH then your ET with gears, and Underdrive pulleys wont change anything.
Old Oct 17, 2003 | 11:19 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
what stall should i get?what u mean they just side over the original one?so i buy them and put them on and weld them over the stock ones?
Old Oct 17, 2003 | 11:21 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes
Old Oct 17, 2003 | 12:35 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
and what does this do?what will see from the brackets?
Old Oct 17, 2003 | 12:39 PM
Dewey316's Avatar
Car: 1990 Camaro RS
it increases the anti-squat of the rear suspension, you can get 100% or more anti squate in the rear end, which drives the rear wheels into the ground .. thus more traction. but if handling is a concer, roll steer will become and issue.
Old Oct 17, 2003 | 11:01 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
what u mean by this?(but if handling is a concer, roll steer will become and issue.)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
