new manifold
Old Oct 21, 2003 | 01:26 AM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
new manifold
i just got a elderbrock performer manifold for free from a friend and its brand new. i was wondering if it will work on my car #3701 its for a sbc but will if it on mine.its a 4 barrel but i can get the tbi plate. if anyone has this one did you notice a diff thanks
Old Oct 21, 2003 | 01:29 AM
vjo90RS8's Avatar
Car: 2002 Z28
that intake is for heads up to '86, so it will no fit without some modifiction to the bolt holes.
Old Oct 21, 2003 | 02:00 AM
Car: 1992 Firebird
well that sucks. oh well i got it for free.
Old Oct 21, 2003 | 05:57 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the modification is pretty simple, just use a drill and elongate the center 4 holes. so you can bolt in onto your heads.
Old Oct 21, 2003 | 06:40 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
i just did a similar thing with a performer rpm intake. it just took a lil drillen and file-en... now it fits good!
Old Oct 21, 2003 | 01:44 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Does that manifold have a way for you to run EGR? If not you have to delete it from your chip. You may also have problems hooking up the throttle linkage as well as any other sensor that that manifold may not have provisions for.
Old Oct 21, 2003 | 03:02 PM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
i don't know about the performer but the p rpm does not have egr... but i have a carb now and the throttle was easy i just used a steel spacer with 2 holes in it and stuck them together.
Old Oct 22, 2003 | 08:48 PM
Car: 1992 Firebird
its a egr manifold
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
