open air cleaner on a TBI
Old Nov 6, 2003 | 10:29 PM
matching#s's Avatar
Car: 89 rs convertible, 99 Tahoe custom, 71 RS/SS 350 camaro (in restoration)
Engine: 305, 350, & 383 stroker
Transmission: 700r4 & Th350
Thanks for the help guys. I have a 89 rs convertible with a 5.0 305 TBI. I'm about to put a 3" cowl hood on her and want to run an open air cleaner. I'm not used to workingond CPU controlled cars. I deal mainly with 2nd gen camaros. Is there anything I have to do the
CPU or anything else? Will it run right? Thanks and have a good one my friends.
Bob
Old Nov 6, 2003 | 11:54 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
all you need to do is plug the vacuum port on the tbi for the thermac crap and move the intake air temperature sensor to the firewall. Its the two pin sensor thats screwed into the aircleaner. Thats about it.
Old Nov 7, 2003 | 06:30 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
thats what i did. no problems for almost a year
Old Nov 7, 2003 | 07:08 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yup, these guys are right. And if you don't want to relocate yout IAT you can just pop it into the bottom of your open element by drilling a .5" hole or so. That is what I did and it works fine. Go buy a pack of vacuum caps and pick one out that will fit over the thermac port. Total investment for this is like 20 to 25 bucks. Maybe cheaper. You will love the results and your car will thank you.
Old Nov 8, 2003 | 01:34 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i agree.
but, you may want to get a new IAT sensor while you are at it. its only like 7 bucks, and its worth it while you have it out.
you may or may not feel anything when driving, but you will DEFINITELY be able to hear the difference.
have fun...
-brian
Old Nov 8, 2003 | 01:49 PM
joshwilson3's Avatar
Old Nov 8, 2003 | 03:35 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Any auto pats tore will have it. I replaced mine with what autozone had and i think it was ac delco. I may be wrong it was awhile ago.
Old Nov 10, 2003 | 03:10 PM
matching#s's Avatar
need clarification
Hey, guys thanks for your help. I would like to pick up a new sensor for this appliction. I have gone to both Kragen Auto parts and napa auto and niether one can figure out what a IAT sensor is, so I just wanted to clarify with you. They both kept talking about hte manifold air temp sensor and the air cleaner temp sensor. I am almost positive that I am looking for the air cleaner temp sensor, correct? Just wanted to double check. They run $20 in my part of the woods. Is there anything else I should do? Any other sensors that should be replaced, even if it's a just-in-case replacement? I was planning on replaceing the ingnition wires (got the accell 8.8mm), HEI cap, and plugs since I bought it used. anyone have any ideas on a good straight forward HEI replacement cap? Would a better coil helps these engines out at all? Okay the questions just seem to keep growing. Enough for now. Thanks and have a good one my friends!!
Bob
Old Nov 10, 2003 | 03:46 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Here is the GM part number for it 8997787. it is refered to as the Air Temp Sensor. You can find it on www.gmpartsdirect.com. I think it is cheaper at a parts store.
Old Nov 10, 2003 | 03:48 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
thoes air temp sensors rarely fail...... you dont need a replacement.
just keep it someplace that isnt excessivly hot in the engine bay.... for example, dont hang it over the headers/manifold..... and dont let it touch hot metal...
i would suggest putting it in the air cleaner housing if you can. otherwise, on the firewall over the engine is fine.
Old Nov 10, 2003 | 03:52 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
im with Mr Dude, it rarely fails and it really hardly does squat anyways in the calibration as far as i know.
Old Nov 19, 2003 | 08:01 PM
25thanniversary's Avatar
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
watch out
if your getting a cowl hood try not to get a bolt on... i had four pins on mine and it flew off on the freeway so if you get fiberglass pin on make sure to use at least 6 pins
Old Nov 19, 2003 | 08:19 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Had to be some kind of coicindence or something, I JUST got done bringing an old thread about open elements I started when I first joined TGO! You may want to check it out. There is a LOT of info in it and some MAJOR things your gonna want to heed caution to, also. If you have any other Q's let me know (pm me or something) and I'll be more than happy to help ya!
LINK:
Open Element on 305TBI
Bruce (90RS305)
Brinkkl2000
Aug 4, 2018 08:29 AM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
