L98 heads on the TBI 305
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I know that there was a thread about this somewhere in the past but I cant find it, basically I need to know what the mods are to get the aluminum heads from the L98 to bolt up to the 305, thanks.
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
Well the D-port (113?) L98 heads use the pre 87 bolt pattern so your going to need an intake to fit.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The combustion chambers are a little bigger than your stock ones. 64cc compaired to 58cc so your compression will drop a bit.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Axle/Gears: 3.08
Originally posted by brodyscamaro
IIRC, Al L98 heads have 58cc combustion chambers.
you are correct, 58cc. good head for the 305 IMO. Joined: Feb 2001
Car: '90 RS
Engine: 377 LSX
https://www.thirdgen.org/techbb2/sho...n+chamber+size
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
he is talking about alum. heads, he said it right on the second line of the first post.
so yes, the heads in question do have a 58cc combustion chamber.
Yes the heads are a bolt on. The only modifications you have to make are to the inner four bolt holes on your intake manifold (if you use the stock or a 87 and up intake). You will need to elongate them so the bolts will line up correctly. If you plan on using an aftermaket intake then just get one for a 86 or older sb chevy.
Steve
Steve
Car: Camaro RS
Engine: L03 305
Does anyone have the specs on the limitations of the valve lift before the valves would interfere with the cylinder bores? I'm hoping to use a zz4 or similar cam in my build. Thanks.
Axle/Gears: 3.08
Car: 1990 Camaro RS
i beleive that 1.94/1.5 valves will work on a 305.
BUT, i have a VERY long conversation on valve sizes with Harold Brookshire from Lunati (and formerly UltraDyne Cams) when we were picking cams for my 305 build-up, he told me with his cams, to stick with 1.84's on the 416 heads, he said there would really be no gain, and maybe even a loss from going to 1.94's. he said it had to do with the actualy flow of the ports vs the valve size, and the exaust flow. said with the 1.84's on mildly ported 416s will keep the intake velocity up, and having the valve not so close to the cyl. wall, it should actualy give me better real world HP numbers than the 1.94's. especialy considering most of us 305 guys are not trying to make our power at 7k, we are generaly looking to keep our torque up.
Car: 91 Red Sled
Originally posted by Rock90rs
I Do know I have been told that a larger than stock (ie. 202/160) valve will not work with a 305 bore on the 113 heads. Any imput?? Ive never bothered to check it out myself.
Car: Camaro RS
Engine: L03 305
So basically what I'm getting from this is that I can use any small block heads I want so long as they have around a 58cc combustion chamber and the valve sizes dont exceed 2.02/1.60, however I would probably benefit from staying with the valve sizes I've got now except maybe for a slightly larger exhaust valve, right?
