ZZ4 Cam with Stock L03 Heads?
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
Hi,
can i use the stock L03 heads with the ZZ4 cam? I dont know how much Lift can be used with these Heads. And can i run the Engine with the stock Prom until i get the stuff to do my own?
Im going to change the whole Valvetrain, Intake, Headers and 3" Open Exhaust. Ultimate TBI already done.
If i can not use the ZZ4, which is the biggest cam for use with the L03 Heads?
Nebu.
Nebu.
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
Your going to have to change valvesprings.
I dont remeber the spec's off the top of my had but the ZZ4 is around .500. Probably want to go with screw in studs too.
Just get some new heads, L03's blow anyway.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If the heads are anything like the 193 heads I have (which are swirl ports like the LO3 heads), they don't have much clearance between the retainer and the valve seal.
.470" is the lift before they hit each other, and allowing .005" of clearance leaves .465" of max lift.
You can find other cams that have similar durations with less lift. You'll have to shop for them. Keep in mind a lot of them aren't going to be roller cams though.
If you do find one that's roller, it's not going to be nearly as cheap as that cam.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 91' Camaro
Engine: Carbed 305
Thx for the info. What about a Crane PowerMax 2032 (214/220, .452/.465)? But i can only use 1.5 Rocker with that, am i right?
Nebu.
Nebu.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
that crane one would likely work , but i am going to ask the tough questions now.
you have THE WORST HEADS GM EVERY MADE on your car. why go through all the trouble without upgrading heads. hell even stock TPI heads, unported would be a much better heads, especialy if you are going for a cam uprade, realisticly any cam upgrade you do will be disapointed, the duration will help a bit, but the heads just don't flow enough to really take advantage of the added lift. now, the ZZ4 head, with some TPI heads, minor port work, and the upgrades for the lift, screw in studs, cut down the valve guids, ect. is likely a 275+ hp 305. that aint bad considering the price of your upgrades, the TPI heads are cheap, you can get them for about $50, add $100 in for machine work, another $100 for misc parts (retainers, locks, studs, ect) and you will be far and away better off than trying to polish the turds on your car now.
Car: 91' Camaro
Engine: Carbed 305
ok ok. i go with the torquer heads
i hope the shipping will not be so high (i live in germany)... they use the same rockers, pushrods and so on like the l03's? do i need new valve springs or are they included with these heads?
Nebu.
i hope the shipping will not be so high (i live in germany)... they use the same rockers, pushrods and so on like the l03's? do i need new valve springs or are they included with these heads?Nebu.
Car: 1990 Camaro RS
it depends on where you get the heads from. i am pretty sure everything will move over, the only thing to check is if they are using guidplates, either need new pushrods, and rockers, or you need to take the guideplates off. also i would suggest new rockers, the stockers are called rubber rockers for a reason. most aftermarket springs are good to about .550 lift, so you shouldnt' have to worry there.
theshackle
Mar 5, 2017 06:37 PM
