tuning issue
Old May 2, 2020 | 09:50 PM
  #101
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: tuning issue
I haven't dealt with an ADS file for years. So I don't know how changes are made.
RBob.
Old May 3, 2020 | 10:39 PM
  #102
Armored91Camaro's Avatar
Car: 1992 Camaro RS Heritage Edition
Engine: LO3 305 5.0L v8
Axle/Gears: 10 Bolt Factory 2.73 Open
Re: tuning issue
RBob.
I changed the areas you said to change, i havent started the car yet as its late here 11:30pm , but i did notice that when the key is turned to the on position the check engine light flashes constantly instead of staying solid like it usually does. Ill crank it in the morning before i goto work, worse thing that can happen is limp mode i think.
Old May 4, 2020 | 07:12 AM
  #103
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: tuning issue
The fast flashing CEL is limp mode. Likely didn't get the checksum to update with the BIN changes.
RBob.
Old May 4, 2020 | 08:22 AM
  #104
Re: tuning issue
RBob.
hmm, that is possible. I used a new .bin file and changed those perameters first then changed everything else i wanted. I cant rememeber if i saved imediately after changing the parameters for SA to be shown.
The car did startup and run but check engine continued flashing. So i resorted back to my other chip.
I will start over with another new .bin file and see what happens. It will be atleast another 10 hours before i can do anything though.
Street Lethal
Apr 30, 2019 12:14 PM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 13, 2015 07:35 AM
mizz0313
Aug 12, 2015 06:45 AM
